Audio Issue in Win 8 CP x64
JOYGR11
Kolkata, India
i'm getting a crackling noise / robotic sound from my 5.1 speaker connected to pc via 3.5mm audio jack ... i'm using win 8 CP x64 ... motherboard has inbuilt audio chip by VIA ... audio codec - VT1708S .... though i'm using the latest driver ver. (v9.8), it can't solve the issue .. tried running it in win7 compatibility mode but to no avail (though the HD Vdeck is running 'n' i can access the settings from UI).... strangely it was working fine in win8 Dev Preview x64 .... the main prob. is that w/o VIA audio driver, i can't get front panel audio output via headphone ... i uninstalled it .. now the audio is fine with default microsoft hd audio ....
pls help if anyone can solve this crackling audio issue with VIA audio chip .... :think:
    WINDOWS 8 Consumer Preview x64
    Assembled
    INTEL CORE I5 2400
    Gigabyte GA-H61M-S2P-B3 (rev. 1.0)
    Corsair XMS3 (2x4GB) 8GB DDR3 1333 MHZ
    PALIT (NVIDIA) GTS 250 1GB
    Inbuilt (VIA VT1708S)
    Samsung Syncmaster 2033SW
    1600 x 900
    Western Digital (WD) Caviar Green 1 TB
    Western Digital (WD) Caviar Green 500 GB
    CoolerMaster Extreme Power Plus 600W
    Generic Mid-Tower ATX (Frontech)
    x2 CoolerMaster LED 12CM Chassis Fan
    Logitech Multimedia Keyboard
    Logitech PS/2 Mouse
    512 kbps Broadband
Hi,
First try updating your wireless adapter driver from the chipset maker's website. (VIA, Realtek, Broadcom, Intel, Atheros)
If that doesn't help, try updating the motherboard bios version.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
ok. i'll see if it works ...
but what is the connection between wireless driver & audio ?
P.S. i dnt hv any wireless adapter ....
    Assembled
    INTEL CORE I5 2400
    1600 x 900
    Logitech PS/2 Mouse
    512 kbps Broadband
    Assembled
    INTEL CORE I5 2400
    1600 x 900
    Logitech PS/2 Mouse
    512 kbps Broadband
On the page you linked to is a bios revision from February of this year to install.
Also on your linked page is the newest audio driver. After the above is tested, install the audio from there to make sure this is the version Windows uses. It's also a good idea to check that all the drivers from that page are installed.
Other than that, VIA audio is definitely seeing its issues on Windows 8.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Joygr11, it's not just VIA audio. People with Creative devices, myself included, are having the same issues. We will probably have to wait for various drivers to be updated by each manufacturer.
    Windows 8 Consumer Preview
ok ... so we hv to wait ...
    Assembled
    INTEL CORE I5 2400
    1600 x 900
    Logitech PS/2 Mouse
    512 kbps Broadband
Hi there kramvk. I've seen something that VIA is definitely working on a beta driver for Windows 8. I don't think it will take long for it to be available.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
My hp laptop scared the heck out of me after shutting down: big explosive-crackling noise from the speakers.
I had some issues with IDT high definition audio not installing properly: very notorious by now, it always had the same problem with linuxes but this is also with Windows 8 now.
The drivers that hp gave are for Vista and work only in Win7: in Win8 CP (x86 and x64) sound doesn't work with the same drivers.
The machine is: hp dv7 3100eb.
I'm gonna stick to Win 7 on this laptop until new drivers are available (don't wanna hear those explosions at shutdown again)
Thanks
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
