HDMI No sound
    Windows 7
    HDMI No sound
    Hi, for the first time ever I'm trying to connect my laptop to my TV via a HDMI cable, everything works fine apart from the sound, it's being played via the laptop for some reason.
    I went on the sound options on device manager, the "Digital Audio (HDMI)" option says "not plugged in" therefore I can't enable it to play it through the TV. I've also tried to change the projection to "projector only", no luck.
    I went onto "device manager" every one of my drivers seem updated, apart from a single one which I don't even think is currently downloaded. I try to use the "update" button however it can't find the driver online. I don't know which driver it is therefore I can't download it manually either.
    My laptop is a "HP Pavilion g6" and TV is a Philip, not sure of the exact model however. I've left some screenshots below to help you geniuses with assisting me!
    I figured it's a "Realtek" device, but not sure which one
    Please help!
    San Jose - California
    Check if you have Intel Chipset Drivers installed.
    Open registry and under: HKEY_LOCAL_MACHINE\SOFTWARE\Intel\InfInst
    The latest version should be: 10.0.13
    If it is missing then download and install the drivers. Intel Chipset Drivers should install any missing drivers for the built in devices on the MB such as USB, HDMI etc... and hopefully the yellow exclamation mark will disappear.
    Windows 7
    Quote Originally Posted by topgundcp View Post
    Hi, when I checked it was one version 9 something, I updated it however the missing mark is still there, here's a screenshot:
    When I run the Intel driver update utility here's what the results are:
    You might also want to check if you have the latest BIOS firmware.
    Windows 7
    It looks too hard to update but I can say that my laptop is always updated when it needs an update.
    Quote Originally Posted by Gurses View Post
    Understood. It's a little scary for most people when dealing with BIOS update. However, we are in the process of eliminating the problem and often the BIOS update is neccessary to correct some of the problems with built in devices.
    Windows 7
    Do you know a suitable and easy to understand guide you may be able to link me? Thanks for the responses bro.
    Here's the link to show you step by step what need to be done to update the BIOS:
    Updating the BIOS | HP® Support
    Windows 7
    Don't laugh but I just restarted my laptop and it worked :| Thank you for the help bro!
    Hey, good to hear it's working. So you did not restart after updating the Chipset Drivers ?
Page 1 of 2 12 LastLast
HDMI No sound
Hi all. I sucessfully got bootcamp to work on my iMac, and the only issue that I have run across is that I do not have any sound whatsoever coming out of my speakers. The sound icon just remains at the speaker with a red cross, and no matter what I do, I just can't get it to work. In...
Very helpful forum so thanks in advance for addressing this - I have an Asus laptop running Intel Display Audio and I have it connected to an external monitor via HDMI. I also have external logitech speakers, which for whatever reason, sound a lot better when plugged in to the monitor than the...
Asus hdmi tv sound problem in Sound & Audio
I have a Asus N750JV. My problem is that when I want to play a movie on the Smart samsung tv with my HDMI cable the video is perfect but the sound is still playing from my laptop instead of the tv. 48970 Thanks for helping in advance. Greetings
Just when all was going well....system has decided that my HDMI connection...hitherto without problems ....is now 'unplugged'....and no matter what I do (reboot..switch devices on/off)....I now have no HDMI connection Well...VIDEO is present....but NO SOUND I've just wasted an hour trying to...
I have a PNY Geforce 210 1024gb graphics card 1480914810and I am using the hdmi cable to my desktop computer to my Samsung 43" plasma tv. The video works amazingly well but there is no audio from hdmi14811. I even have the latest Nvidia driver. I tried everything and the end result was giving up...
No sound with w8 and HDMI in Sound & Audio
Hi there, I have recently acquired a gaming PC which has been built up from scratch by a local in my area who has good reputation for reliability etc. Most things are working fine, however I cannot seem to get the sound working through my television, which is my main (and only) monitor. The...
