Random Sound failure
    Hi,
    My acer (aspier v5 171 Series) (windows 8) has been working smoothly for 1 year now, but since couple of days the sound would go off if something is not being played for sometime. then I need to restart to get it back...initially I though it happens after I lock the laptop but today it went off even without locking.
    all the sound icons like speaker icon, volume bar is functional but with no sound.
    any pointers?
    Did you try updating your sound card drivers?
    let me try that...thanks
    no luck, it says "Windows has determined that driver software for this device is upto date"
    Win 8 64-bit
    I can't help you, but I had the same thing about a month or two ago, which was the same as you (I.E. the audio intermittently wouldn't work unless I rebooted, although the on-screen volume display in the top left of the screen didn't work for me either).
    I don't know how to cure it as the problem seemed to go away by itself, although I wonder if you go to Control Panel > Action Centre > Maintenance > View Reliability History whether it may give you some clues. With mine it came up with 'Windows Audio' and 'Audio Endpoint Builder' svchost APPCRASH errors (and showed faulty module as ntdll.dll). If it shows some errors then it could give you something to search for on google.
    I would try uinstalling the sound driver entirely and then restarting your PC. See if it detects a sound card and go from there. Try that and see if that resolves the problem.
    If that doesn't resolve the problem a refresh may be in order
    Refresh Windows 8 - Create and Use Custom Recovery Image
    Thanks ARC1020, I had no records in Reliability History it was blank. LoveNPower you the man... uninstalled the driver and restarted... the speaker icon was covered with red box then windows installed the driver, though it said installation not successful..it now works...atlest for now...
    Cheers
    Quote Originally Posted by liferockss View Post
    Cheers
    Good to hear your issue is resolved. If any further issues arrive don't hesitate to post back.
I noticed https://www.eightforums.com/bsod-crashes-debugging/47857-bsod-driver-state-power-failure-randomly-new-asus-g750jm.html and decided I needed to come here and report my own error with my G750JM. It's only happened twice, but the second time sparked me to try and figure out whats causing the...
Solved Random BSOD: Kernel Security Check Failure in BSOD Crashes and Debugging
Hi everyone, Since today my friend is being hit with some BSOD's containing the text: "Kernel Security Check Failure" We have no idea where this all came from, my friend did not download some sketchy, unstable, downloads or something. We did some research and it apparently is an issue with...
Solved Random BSODs (Kernel Security Check Failure) in BSOD Crashes and Debugging
Hello there! Lately I've been getting the same BSOD over and over. It wasn't as bad at first, but at this point it happens almost every day, sometimes multiple times. I'd appreciate any help :) - Xythus
BSOD, seems to be random, POWER STATE FAILURE in BSOD Crashes and Debugging
Hi all, First time posting to forums, I hope I did everything right. So Since upgrading to windows 8 pro about 2 weeks ago, My computer seems to BSOD with DRIVER_POWER_STATE_FAILURE. I attached the pulled from the "SF Diagnostic Tool". and attached them to the thread. Could someone take a...
Hello, I started to get this bsod randomly, even when computer is not at 100% load. When I shutdown computer it creates dmp file with error too. When computer bsod with kernel security bsod it creates log with bugcheck error 0x00000139. Your help would be appreciated.
Random ticking sound inside Laptop in Drivers & Hardware
Hi, I'm getting this random clicking sound(more of a tick-tock-ish) that's coming from within my system. I'm not sure where but it's adequately loud for me to notice. It just goes 2 clicks(tick-1 tick-2) then goes away. It doesn't have a specific time frame, like it doesn't happen every how many...
Hello, I am getting a random notification sound but no notifications are appearing in Windows 8. I have isolated it to be the default asterisk sound but nothing is plugged into my computer, not even the power cord, and I will still get the random sound. Any ideas? Thanks!
