Please help with burning a cd
    My windows 8 does not respond when I hit the "burn to cd" button. Can anyone help, Thanks!
    Windows CD burner is not too good program. Suggest using this instead: https://www.ashampoo.com/en/usd/pin/...rning-Studio-6
    64-bit Windows 8.1 Pro
    If you need a totally free burning software, I recommend Imgburn
    The Official ImgBurn Website
    Along with Imgburn, CDBurnerXP is another good free burning program.
    But, a little more information on what program you are using and exactly what you are trying to burn would help. Maybe its not a problem with whatever program you have but some other issue.
    Harrisonburg, Va.
    I use usb drives.
    Easier than CDs or DVDs in my opinion.
    Thanks for the responses guys. I am mainly burning music cd's. I downloaded IMGburn, without much luck, my truck cd player says the discs are bad, and i got trovi stuff and adware on my computer from the download. I was thinking about Nero, but all the reviews are pretty terrible.
    Which kind of music CD ? .MP3 or older Music only CD .. Older car radios can not read MP3.
    As I have a recording studio I do a lot of audio CD burning (not MP3). The burn speed must be kept low to be compatible with many older audio CD players. My burn speed standard is "8X" however most SATA CD/DVD burners will only go down to 16X. Thus if you are making an Audio CD use the lowest speed.
    Audio CD's burned at high speeds that will not play on a given audio CD player will either not play at all or will skip.
    MP3's do not have this problem as they are basically "data" CD's and can be burned at high speeds.
    Nero works fine for CD burning. I use Nero BurningROM for all my audio CD burning. However, Nero like many programs, has become a relatively large (bloated) program for all burning needs, not just a CD/DVD burner like it started out. I use the Nero BurningROM as it will burn to multiple burners at the same time, something almost all other burning programs will not do, including the high priced Sony CD Architect burning program that is used by many recording studios.
    I agree with David, I'd rather get one of those thingy's one sticks into the cigarette lighter that one can plug a USB into and plays via radio channel than go back to CD's...
    Not everyone has a car audio system with USB interface. I realize CD's may be a thing of the past on new audio stereo systems, but many still have the CD's and/or have a CD player in their home stereo system. There are many that want the full fidelity audio (wav/audio CD) rather than the "something less than full fidelity" MP3.
    I still do a lot of CD burning for local musicians. I have a bank of 5 CD/DVD burners (USB connected) that I use for CD burning production (I can burn 5 at a time with Nero BurningROM). I've burned over 200 Audio CD's so far this year. I recently (in the last two months) bought a Primera Bravo CD printer, to replace the third Epson printer that prints on CD's as they last about two years and then develop problems with the CD printing feature. I only use JVC/Taiyo Yuden ink jet printable CD-R blanks for my CD production.
Solved Burning CD's with WMP in Sound & Audio
I just did some research on the net and found out that an update is in the works for WMP to add the "Burn at once" feature. As far as gapless playing or recording goes I can say that the free copy of "Virtual DJ" allows for gapless and overlapping for playback and record. It's also great for simple...
I recently loaded my music into WMP. The tag info was automatically retrieved and saved to the Library. The track information in my library is accurate. The problem is when I burn music from the library to a CD and play it back in the car the Artist and Song Title don't appear as it plays. When I...
Problem burning cd's in General Support
My friend needs to burn photos to a cd on a regular basis. It has been working for a few months, now it is failing. His usual process is that he selects about 25 photos, goes to Share>Burn to disc. It then opens File Explorer, shows the DVD drive with the photos in there, and then burns the disk...
Hi I would be gratefull for help, just a week or two my inside and outside (USB) recorders started to work extremly slow. Using Nero 14 i can see the real recording speed 800 - 1 500 kB/s when using 16x (22 160 kB/S). My usb samsung blu-ray recorder also work very slow - data fo 25 Gb disc...
Solved burning a DVD? in General Support
not sure where to start with this question so i'll start it here. now I've got windows 8 and I think it's the home edition. now, will this thing burn DVDs on it? I know I can record CDs with it, but I can't find information about burning DVDs, even in this windows 8 for dummies book.
Before burning on a DVD. in General Support
For those that select the download option for Win 8 i have a question. Before burning it on a DVD will there be a way to check if the download was OK and not waste a DVD if there is a problem with it? Thanks.
