no audio on computer, only audio on skype
    Since June-ish i get no audio in any games, Youtube, Twitch, etc. I get audio on skype but thats it. I checked my device manager and it says all audio devices are working properly. I checked for driver updates and found none. I have a Dell XPS 8700. Thanks
    -forsakenbacon17
    Is the "Speakers" (the PC's sound chip) set as the Default Playback Device?
    Go to the Sound Panel, Playback section. That is where you set the default Playback Device.
    I just turned on my computer today and a random update fixed it? Thank you for helping though i appreciate it!
Source...
