Headset Microphone not working
    I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work.
    I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to computer's but I'm stuck here.
    Looking at this headset, on a YouTube video, the mic portion plugs into the headset. Has this ever worked? If not, I would contact Creative as there may be a problem. Or, if you have access to another PC (a friend's) you could try it on that to see if it works.
    As you have both on-board sound and a separate sound card, if you want to use the SoundBlaster you should disable the on-board in the BIOS. Having two can cause conflicts and things to not work. In addition Windows only allows one default audio playback device. Also, where are you plugging in? If its the front panel of the PC case, what audio do you have connected to the front panel? From the motherboard or from the SoundBlaster? Again, if you are using the SoundBlaster but have the motherboard audio connected to the front panel it won't work.
    I have a Fatal1ty motherboard in one of my PC's, it is an ASRock Z77 Professional Fatal1ty.
    Win 8.1u1
    Quote Originally Posted by TempusFugit View Post
    Check out the manual on the sound board and review this site (Tip and ring: Information from Answers.com).
    There are two "standards" for headsets with microphones. One, commonly used on smart phones and tablets, is a 4 contact (Tip-Ring-Ring-Sleeve) plug and jack set where the microphone is "piggybacked" on the stereo headphone signals. The other standard is common on sound cards used in desktop and notebook computers and it uses a 3 contact (T-R-S) plug and jack for output to the headphones and a totally separate 2 conductor jack (T-S) for the microphone input.
    If your headset uses a single T-R-R-S plug and your sound board is designed to accept two separate plugs (1 T-R-S and 1 T-S) and you plug the single headset/mic plug into the sound boards headphone only jack you will get a signal to the two headphones earpieces but the mic is left unconnected.
    There are quite a number of splitters on the market. With the correct version, you can adapt a single plug headset/mic combo to a board that wants two separate plugs.
So the other day i bought a Logitech for 15 and i get home to recorded my voice but my laptop wont pick up my headset..Like it knows its been plugged in etc and will even play sound through the headset but can seem to get it to pop up on my microphone bit! Could someone help me please?
Hello Eightforums. Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack....
Microphone not working in Sound & Audio
Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the...
Hello~ I was recording with my internal realtalk hd mic on my laptop, but it stops working everytime I plug in my head set. There's nothing special about this headset, and there's no microphone on it. Sadly, my RT mic does this with any headset I use. It's frustrating when I unplug my headset and...
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
Microphone is not working in Sound & Audio
I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is...
