Sound issue
    Windows 8.0
    Sound issue
    Hello! I have an HP laptop running Windows 8. Yesterday Windows updates were pushed across that I'm quite sure did not upgrade me to 8.1. Since then, after leaving the Chrome browser, I seem to have lost sound...and iTunes opens but will not play anything. To regain sound, I have to run CCleaner, cleaning out temp files, and restart the machine. I've tried to narrow this down to visiting a particular site, or running a particular process, but can't. Anyone else experience this weird problem? Thanks!
    With only Windows 8.0 and the updates that were installed, that potentially could cause a lot of problems. Windows 8 is now up to 8.1.1.
    No one else, on here that I know of, has reported this problem.
    Windows 8.0
    Thx, Fireberd, I'll check back from time to time and post something if I get a fix.
Sound issue
Hi. I recently bought a new pc and for the first few days the sound was working fine. This morning, some sound is not working, and some is working fine. Some youtube audio appears to be working and other youtube audio does not work at all. It seems like sound on certain frequency or band is working...
Windows 8 sound issue in Sound & Audio
Hello, After deciding to give windows 8 another shot and installing windows 8.1 i still stumbled upon the same issue i had before. sound - YouTube In first part of the clip you can hear sound in windows 7 and in second how it sounds in windows 8. While windows 7 sounds perfect, windows 8 has this...
Hello! Having a bit of a problem and trying to see if there is an easy solution. I have a Surface Pro and I want to watch some video on it. I wasn't able to find a specific video app that would play MKVs, but I did find Files&Folders which has a built in player that actually does! Been...
Asus M4A88T-M sound issue . in Sound & Audio
hi, i've just installed Win 8 . when it finished , i had sound , but only from 1 speaker ( i have 5.1 ) i was trying to install M4A88T-M audio drivers , but it says that no HD AUDIO found , and then i tried to install AC-97 drivers , but there's no drivers for win 8 . is my motherboard that...
wierd windows 8 sound issue in Sound & Audio
Hallo there. I upgraded to windows 8 some weeks ago, as i got it trough dreamspark. I got this huge problem, on both my stationary, and my laptop sound keeps dissapearing for 4-5 secs every 2-4 mins. And it's really annoying. I got 2 soundcards on my stationary, and ive tryed using both...
Sound issue Windows 8 in Sound & Audio
Hello, I have sound issues on Windows 8 new desktop, in apps and in IE10 it dont play sound. When i open the "old" desktop and open in there Internet, its working. I have updated the Realtek sound card, but this not resolve the issue, does somebody know how to solve this issue?
