  1. #61
    google chrome
    UGH so frustrating - did ya make sure it is not back on there? Also did you ever call HP and see what they say?
  2. #62
    Just joined as I am having the exact same problem! Restart solves it but only for about 5 minutes- SO frustrating! Guessing it is the Windows update as I also recently updated- doubt it is a HP fault as my laptop is Asus and like I said I am also having the problem.
    Please post if anybody finds a solution, otherwise I guess it's just down to Microsoft!
  3. #63
    Quote Originally Posted by Murray UK View Post
    Same intermittent problem with my wife's laptop Acer Aspire V5-571P. Have applied CathyT's suggestion above. Sound came back immediately. Need to see how long it lasts! Have also stopped Windows auto update and switched to manual for the time being.
    Just to update - after 48 hours sound still loud and clear. Many thanks CathyT for saving my sanity and also to SnowyJoey for the information on Hiding updates. I will do that and then go back to auto update.
    Does anyone know what Microsoft will do about this?
  4. #64
    google chrome
    Jessica uninstall the MS update that they posted earlier - so far it has been a God send for me xxx
  5. #65
    Thanks Vegan Girl, at the risk of seeming quite dumb, how exactly do I do this?! xxx
  6. #66
    google chrome
    Hey Jessica - no worries hun. I followed these instructions 24 hours ago and so far so good xxxx
    I had this problem last Friday after installing the 12 system updates that Microsoft rolled out. I could not play any songs on Windows music player and songs on itunes would not start when I double-clicked on them. Also no sound on youtube videos,etc. I quickly realised that it was something in one of these updates that was the cause of the problem. It took me about three hours of wasted time finding the solution to this problem. As others on here have mentioned previously, the problem is with the Update for Microsoft Windows(KB2962407). You need to uninstall this update. Do not worry that this update is needed and essential. Yes, it is essential, apparently for onscreen keyboards on tablets! Microsoft really are idiots sometimes! I uninstalled this update last Friday night and the sound on my Windows 8 laptop came back again. Unfortunately, it is not just as simple as that though. The following day(last Saturday) this update went and installed itself again so you have to stop the update from re-installing itself. Here is what you need to do to get your audio back. Trust me this will sort out the problem as I did this last Saturday evening and it is now Thursday night and I have experienced no more audio problems on my Windows 8 laptop.
    Go into Control Panel - then click on Windows Update.
    Bottom left of page click on Installed Updates. Go to right of page and click on Installed On. This will show the most recent updates to your system. I had a list of 12 that were installed on 10/07/14. The Update for Microsoft Windows(KB2962407) will be here. Right click on it and Uninstall it. This will probably take about ten minutes or so and your laptop will re-start. Now you need to make sure the update does not re-install back onto your system. Again Go back into Control Panel - Windows Update. Click on Check for updates. The system will search for updates and it will show that 1 important update is available. This will be the dreaded KB2962407. Right click on it and press Hide update. Then hit the OK button. This will stop this update from being re-installed and you will have no more audio problems.
  7. #67
    Thanks Vegan Girl, will let you know how it goes! xxx
  8. #68
    All working now, will see how long it lasts! Many thanks Vegan Girl. xxx
  9. #69
    Quote Originally Posted by CrimsonSkies View Post
    I've uninstalled KB2962407, and it worked fine all last night, but now again it's showing the "This device is being used by another application..." and the sound isn't working.
    CrimsonSkies
    As I mentioned before in my previous post if you just uninstall the KB2962407 update, that will not fix this problem as KB2962407 will just re-install itself and the sound problem will be back again. Check your windows updates to see if it has re-installed. If yes, uninstall it again and then from Control Panel go into Windows Update and click on search for updates. When the KB2962407 update appears after this search you need to right click on it and press Hide update. Then click on OK. Now that you've done this, the KB2962407 update will not re-install itself and you will no longer be offered this problematic update.
  10. #70
    windows 7
    update
    Same problem, Dell laptop/Windows 8. Also lost visibility in my homegroup around the same time.
    Applied the fix, no change in homegroup, will take a day or so to determine if the audio is corrected, thanks for the info.
Page 7 of 10 FirstFirst ... 56789 ... LastLast
Has anyone made a sound changing app where you can change startup/shutdown sounds ect? Can you via registry and other tricks get sound to happen on fast boot and resume? I wonder if I could get windows task scheduler to do it...mmmm
