  1. #31
    Win7
    Installing 8.1 seems to have solved the issue. Thanks for all the help on this.
    Update to Windows 8.1 from Windows 8
    Update to Windows 8.1 from Windows 8 - Windows Help
  2. #32
    United States
    Windows 8.1 Pro 64-bit
    Wanted to say I have 8.1 on Acer and don't have the problem. Realtek HD audio.
  3. #33
    I sucked it up and updated to 8.1. Took a couple of hours. PIA.
    Problem solved for now.
    Samsung Series 5 Ultrabook
  4. #34
    United States
    Quote Originally Posted by GordonX View Post
    I believe Microsoft has said people need to upgrade soon or future updates will not be available. You're ahead of the game now.
  5. #35
    No Sound
    Hi ... was happy to read I was not alone on sound problem. Came back from vacation, turned on Laptop and everything worked great. While shutting down July 13, Windows was performing a "Critical Update". On Monday I had no sound whatsoever. I tried everything and nothing worked. Tonight I did a "System Restore" and chose the update of July 13 - the most recent one which was labelled "Critical". It worked and my sound is back. Nothing else was affected by the restore. The restore took about 10 minutes and rebooted on it's own. I tested it with a video and it was so nice to hear the music again.
  6. #36
    Also went and updated to windows 8.1. Problem is gone! ASUS laptop. Thanks everyone!
  7. #37
    I also have my sound gone, after the so called Win8. Its like sharing the pain, I wish that fix my sound
  8. #38
    Quote Originally Posted by smruti View Post
    Just one of the reasons 8 was replaced by 8.1 in such short time.
  9. #39
    6.2.9200
    SIMPLE SOLUTION EVERYONE!
    I’m not a computer expert in terminology or skill but found the solution for my computer. People are talking about getting 8.1, but unless you’re getting it for free (unlikely), no need to upgrade. Perform a system restore on your computer dating before the last update. I restored from 6/27.
    After the restore only half my volume worked (the left side). Left click the “speakers” icon on my bottom right à Left click the “speakers” icon located above the volume...the only symbol that looks like a speaker above the volume... à Once you get to speaker properties select “levels” (from the menu options) à The first should be your Audio output. To the right, you will see “Balance” à Select balance à It will show the “l” left side and “r” right side volume balance à Adjust and your speakers are balanced.
  10. #40
    The HP Community forum has a possible fix for this problem. It is to uninstall Microsoft update KB2962407 that came out in June, which is when I started to have the problem. There is a fix in KB2962407 that states it fixes "Shortened battery life when an idle audio device is not turned off on a computer running Windows". This update applies to Windows 8 and 8.1. The problem is sporadic for me, so it is too soon to tell if it is the solution. For another person who uninstalled the update, he has not had the problem reoccur, and I believe it was a daily problem for him.
Page 4 of 10 FirstFirst ... 23456 ... LastLast
Has anyone made a sound changing app where you can change startup/shutdown sounds ect? Can you via registry and other tricks get sound to happen on fast boot and resume? I wonder if I could get windows task scheduler to do it...mmmm
