Reset microphone to a new default location
    When I was setting up my microphone I set it up so that the mic comes on when the computer starts. I want to reset it so that it doesn't do that and put it in the Quick Launch toolbar / system tray instead where it would be more convenient a la windows XP style.
    stop speech recognition at startup windows 8.1
    (1) Right click on the speech recognition bar / pop-up and go to configuration
    (2) Next click open speech recognition control panel
    (3) On the left side you should see advanced speech options click it
    (4) Uncheck the Run Speech Recognition at startup and click apply then OK
    Still don't know how to get it into the Quick Launch toolbar
    Disable speech recognition on start up windows 8 - indonetworksecurity.com
    How to turn off speech recognition on startup. - Microsoft Community
A quick Google search did not turn up anything. I want to change the Fie Explorer default opening location from the Libraries to 'This PC -> Desktop'. However, both 'Target' and 'Start In' fields in the File Explorer properties are greyed out. I am an administrator, and as far as I can tell...
Hi, it looks like I made a small mistake that I am unable to repair. I built myself a computer with a SSD and a HDD. When I installed Windows 8.1, I installed it on my SSD which is considered hard drive C. Everything was fine with all my Library and This PC folders (Documents, Images, Musics,...
I am presently running Windows 8.1 32 bit. When I had Windows 7, I changed the default location of my Music files to another disk. They still reside on that disk. I would like to be able to select Music and have my Windows 8.1 system find everything related to Music on this alternate disk. I...
I have Win 8.1 running in my PC; I don't know how and when, but the default location of screenshots (as taken by pressing Win key and PrntScr together) has changed to a random folder somewhere in drive E. I know that location, and if this is possible, how can I change that default location to...
Hello everyone, Always when i install a new version of windows i change the default location of music, documents, downloads etc. Accidentally i change the documents folder to D:Documents without the \ after D: (don't know why windows let me choose this location in the first place). But I can't...
Default Location in Software and Apps
Hi Guys, be gentle with me - I have searched until I'm blue in the face, but cannot find a solution to this issue. I am currently working on a corporate distribution of Windows 8.1 Enterprise I have managed the usual stuff, setting a custom lock screen for all users; setting a default start panel...
Default Location Of Files in General Support
I have a few Programs that have Databases. When the program is setup, the Database gets setup in My Documents. If I chaneg the location to another folder, the Program still shows the Folder in My Documents. Is there a way to stop this?
