Adjust Sound Level?
    Adjust Sound Level?
    Everytime I depressed the volume up/down key on my keyboard, it raises the volume in windows by 6%. Is there anyway to modify this? For example I would like the volume to rise or lower by only 3% everytime I depress the volume control button on my keyboard. I have messed around with the settings and can't figure out how to make this work. Any help would be appreciated.
    Thanks is advance.
    San Jose - California
    I have tried what you said and my volume only increase/decrease by 2 when I press the volume on the keyboard. However, I don't use the keyboard to adjust the volume level. Instead, I use Volumouse - control the sound volume with a wheel mouse and I can adjust the volume level.
    Adjust Sound Level?
    Quote Originally Posted by topgundcp View Post
    I have no ideal what you are talking about as I didn't recommend anything to you (or anyone else) anything. I was the one who asked the question initially.
    You did not recommend anything in your post and I told you that I have tried to duplicate what happened when I press the volume key on the keyboard and it did not happen the way you described, it only raises the volume by 2 instead of 6. In addition, I recommended to use Volume Mouse. That's all.
    So what part don't you understand ?
    Thanks for the recommendation but I use the scroll wheel on the mouse to play video games so it wouldn't be practical for me to use it as a means to raise and lower the volume. I was hoping there was a way in windows in which I could set the volume to raise and lower in increments of 1-3 (while using the keyboard) oppose to just increments of 6.
    Thanks anyhow.
Adjust Sound Level?
Hi all, I am having an issue with the pc I built a few months ago. It doesn't seem to matter how I'm using the PC or what programs I'm running, I keep getting a WHEA_Uncorrectable error followed by a shut down and restart. I have checked and rechecked my drivers, and I canít figure out...
Hello All, Badly stuck up. Working with ACER Aspire E1-510, 15.6 HD LED LCD with Windows 8. UNABLE TO ADJUST BRIGHTNESS. Have tried Control Panel, Fn keys.
How to Adjust Volume Levels in Windows Phone 8 and 8.1 This tutorial will show you how to adjust the volume level settings of items up and down to what you want in Windows Phone 8 and 8.1. Adjust Volume Level Settings in Windows Phone 8 1. Press the volume up + or volume down - button....
Solved can't adjust brightness in General Support
2 month ago i had this problem so i searched for a solution here (get back to the basic display adapter ) and it worked fine and no problem appeared . but now whenever i want to play a game like begone or heroes and generals my cpu usage become 100% and i get 20 fps usually 100 also i cant play i...
brightness won't adjust in Drivers & Hardware
I also have this problem. Can somebody give me a walkthrough how to uninstall the driver, and reinstall the old one?
My new laptop seems hardwired to think that if I set the volume to 20, so long as I have headphones in, I want my volume at 20 for all sounds, ever. This makes music which varies from quiet and loud feel extremely alien and even ruins the feel of some videos and games. But it's most notable when...
