Logitec 960 USB Headset
    win 8 prof
    Please could you help? If I unplug my headphones and plug them back in again the sound continues to come through the speakers and not the headset.The only way I can resolve it is to restart Firefox. I have posted in the Logitech support forum but no one replied. Thank you
    Does the Logitech headphone appear as a device in the "Safely Remove Hardware" function (Icon in notification area in the desktop)? If it does, you must use that to "remove" the headphones before you disconnect them or there can be a Windows status corruption and they will not work the next time you connect them.
    win 8 prof
    Thanks for your reply.
    I'm not sure but the icon doesn't seem to be in the notifications area.
    Here is what it looks like.
    win 8 prof
    I don't seem to have the same issue with Internet Explorer.
so i got an msi gaming z97 micro atx board, but on the io i cant find where the hell to plug in my headset.... there is a mic and the l-output and input well 3 inputs and 3 outputs. i checked the manual but it didnt say it. 56997
So the other day i bought a Logitech for 15 and i get home to recorded my voice but my laptop wont pick up my headset..Like it knows its been plugged in etc and will even play sound through the headset but can seem to get it to pop up on my microphone bit! Could someone help me please?
Hello, I recently upgraded to Windows 8. Previously on Windows 7 I was able to switch between speakers and USB headset on the fly by clicking "set device as default" in windows sound options, without closing media player. Now that I'm on Windows 8, I can't do that anymore: whenever I make...
Can't get headset to work in Sound & Audio
So today I got a new acer laptop with windows 8. The laptop only has one audio/microphone input in it. When I first plugged the headset microphone jack into the singular input, it asked what device it was. I selected headset and moved on. Later, I could not find my headset mic in my audio...
Hi All, I bought one of these Logitech Touch Lapdesk N600 Review | Everything USB It has a slide out touchpad and it is really really good as it is big -- BUT -- I can't get it to do the swipe from the edge thing to slide out the Charms bar (if that's what it is called) Of course I can...
Cannot Remove BT Headset in Drivers & Hardware
I was trying to remove my BT headset from BT devices and now its stuck on "removing device"... won't remove...won't even let me connect the headset now :/ even tried removing them from device manager, after a the device appears again :/ the screenshot is attached
No sound using 360 headset in Sound & Audio
I am using a turtle beach headset plugged in through my xbox 360 wired controller. The device displays in the sound area but does not produce any sound when i try and test it. It doesn't even act like the test is being sent to the device. The mic however does work just fine. Anybody have any...
