Can't run sound-using programs
    Can't run programs that use sound
    Hello,
    ever since I updated to windows 8.1 on my laptop, every once in a while, when i start it up, I just can't run anything that uses sound.
    - What is effected? Apparently every programm (Games, Windows Media Player, Audacity) that uses sound, just doesn't start, or, crashes when i start it up. But games and other programms, that have no sound for any reason run just fine. I can use Chrome with no proplems, but when i watch a video, or go to any other site that requires sound, it just doesn't load, or the area that uses the plugin doesn't work (so e.g. i get a black youtube video area)
    - When does it happen? Recently the proplem appeared sometimes when i started my laptop. Rebooting it usually fixed the problem. But today when i started it up, it just didn't work, nor could i fix it by restarting.
    I am using a MSI GE60 laptop, to which i have a logitech mouse and headset attached, with the required software installed (which crashes when i try to make a sound check). But even when i disconnect the headset pre or post starting the laptop, there's no difference, and even tried reinstalling the Logitech Gaming Software, therefor I'm assuming that's not the problem.
    I would be very thankful for any advice on how to fix the problem.
    Thank you,
    Maxi
    Canada
    Are your Audio device drivers up to date, go to the manufacturers web site to verify.
    The only drivers i am aware of using are the Logitech ones; are there any others i should be aware of?
    Windows 8.0 x64
    Welcome to the Forums.
    One "quick fix" support trick that works maybe half the time or better, is boot into Safe Mode. Then open Device Manager and delete the device with the problem. Reboot. On start Windows will find the hardware and reload the drivers. It doesn't take long to try it and as I noted, in my experience the success rate is fairly high for these types of issues.
    Thanks a lot guys, the "Quick fix" worked
    Windows 8.0 x64
    Glad it worked for you.
Hi guys, hope you can help me with this please because I don’t really know what to do to solve it. I have a Vaio running Windows 8.1. but coming with Windows 8 preinstalled. I have recently noticed that most of the programs and apps (Adobe, Realtek, Sony folder, Intel, Avast, Java, Bluetooth…)...
Hi I have been having an issue with my self built system, not sure if it is hard drive, virus or software conflict. 1- A month ago I started experiencing slow start up and afterwards there would be system hangs and the HDD light would be on for a while before system response. 2- Last week...
Hi, Recently my mom visited a website that tricked her. She downloaded and installed some stuff she didn't need. I removed the stuff but noticed some other problems. I'm not sure if these are new problems caused by the useless stuff she installed. Control Panel -> Programs -> Programs and...
Just noticed that most of the programs have vanished in programs and features (control panel). I have around 90 installed programs. The ones that have vanished still work from the quick launch bar but they have also disappeared from the start menu. Have tried a system restore to the only restore...
