Audio is distorted and computer is slower
    Hi everyone,
    Lately my computer has been distorting sounds and been going slower than it used to. When I restart the computer, the amount of distortions/small sizzling sounds is at a minimum, but it increases as I continue to use the computer. I googled how to fix this and one of the suggestions was to run a system file checker. The result of the scan was that I have some corrupted files that the computer could not remove. However, after doing the command Dism /Online /Cleanup-Image /RestoreHealth and then doing sfc /scannow, it appears the corrupt files have been repaired or eliminated. The problem of the distortions and slower computer still exists. I have attached the sfcdetails.txt file from the sfc scan with the corrupt files and a screen shot of the SFC results right from the command prompt. Thanks in advance to everyone who responds.
    Audio is distorted and computer is slower Attached Files
Mu audio playback all of a sudden sounds like its' under water. Is there a quick, east fix??
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
I have had this computer for about a year now and it recently started acting up. What happens is the audio begins to distort and than the computer freezes if I close something out. This only used to happen when a lot of stuff was running at once or a big game was player, Spore for example. Recently...
Since June-ish i get no audio in any games, Youtube, Twitch, etc. I get audio on skype but thats it. I checked my device manager and it says all audio devices are working properly. I checked for driver updates and found none. I have a Dell XPS 8700. Thanks -forsakenbacon17
Hi everyone, Lately my computer has been distorting sounds and been going slower than it used to. When I restart the computer, the amount of distortions/small sizzling sounds is at a minimum, but it increases as I continue to use the computer. I googled how to fix this and one of the suggestions...
Sound garbled/distorted in Sound & Audio
For reference, I'm using the PCI version of the Sound Blaster X-Fi XtremeGamer. Lately my sound has randomly become distorted with a buzzing-like tone to it that gets progressively worse until I restart my computer. Also, at times the sound will just randomly mute until I use the Creative...
