audio not working
    window 8
    audio not working
    i am using lenovo g500s notebook. i have a problem with sound. sometime no audio comes from speaker but its comes automatically after restart the laptop... i have up to date drivers.....plz help me out
    If this happens while you listen to an Internet Radio, the problem may be with the transmission.
    window 8
    no...i do not use internet radio... it happen automatically .. then i am restart laptop...sound comes for few minutes....then after same problem occur
    You need to tell us more about your system, about your current driver for your sound, please fill up the system specs and make sure you have the latest driver for your sound.
audio not working
i've recently installed win 8.1 pro N x64 and this has stopped my onboard sound card from working. my mobo is the MSI big bang xpower ii, it was working fine under win 7 home edition x64 but now refuses to do anything. when i try to test the playback device the green bar moves sporadically up and...
Solved HD Audio Device not working in Sound & Audio
Hi All, I searched the threads but could not find a solution. My High Definition audio device is not working. This is the error message, This device cannot start. (Code 10) {Operation Failed} The requested operation was unsuccessful.
So suddenly when the my laptop sleeps or turns the screen off, the audio device gets taken over by some hidden application or the optional update was just faulty. I've been experiencing this for two days now. Check the picture for more information 45223
Solved IDT hd audio not working in Drivers & Hardware
Just a question: Has anyone found decent drivers compatible with Win8, that work, for the IDT high definition audio on HP pavilion DV7 laptops? Thanks Hopachi
I was just using my earplugs on my Windows PC and I when I disconnected them, my audio stopped working. I have a quad-boot of Windows 8 Pro, Windows 8 Release Preview, Windows Developer Preview, and Windows 7. Sound doesn't work on any OS but Windows 7. When I play music on the Music app in...
Hi All Just downloaded Windows 8 Professional from Dreamspark Premium. Installation has gone really well and I'm getting used to it already, but there's a slight problem - no sound Has anyone got any instructions for sorting this out? the laptop I'm using is a HP Pavillion DV6-6b50sa which...
