How to set sound volume on boot?
    When I boot the sound volume is whatever I left it when I shut it down last time. I want to reset it to 20 each time I boot. Is that possible?
    Windows 8 Pro
    I'm not sure it's possible within windows itself...there may be a program/script that you can run on boot up or shutdown that resets the volume to a set level.
    Looking around , there is something called Autohotkey with a Soundset option that changes the volume...suggested by techguy.org here...
    How to adjust volume by a batch file? - Tech Support Guy
    Autohotkey MAY work, but it would have to be in the startup. However, it would have to load after the sound driver loads and when the sound driver first loads the sound would be at the volume it was when shut down, thus the startup sound will be loud and autohotkey won't help you on bootup.
    Windows 8 Pro
    I was thinking more out of the box, run it on logoff to whatever level he wants , when he restarts the PC the setting will revert to that level.
    I was already using Autohotkey, so just added this script in my startup folder, which works fine:
    SoundSet, 20
    return
    thanks
Unmountable boot volume in General Support
I got a new laptop 3 weeks ago, and now after a hard restart i got the Unmountable_boot_volume error. When i power up it sits loading for 15 mins before i get the message something is wrong. It then proceeds to a new restart where it says starting automatic recovery, then the screen goes black...
Greetings! I'm having a little problem here which I wasn't quite able to solve using the official Creative Support. First a little explanation: Before installing my new Sound Blaster ZxR I had to temporarily use the Onboard Sound of my Asus Rampage IV Black Edition because of a SLI Water...
Hello everyone, First of all, this is my first post on the Windows 8 forums, I've had this laptop for 3 weeks now and for the most part, I'm starting to get used to 8.1. However, there are still a few problems that make me feel terribly powerless. For one, whenever I plug in my headphones,...
Hey guys basically i have an ASus ux301la (zenbook infinity) and i noticed that after installing Displaylinks software (port replicator software) my default sound device was called (USB AUDIO) and that my Realtek sound device kind of went missing (no sound devices on the playback tab in the sound...
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
I have set the volume mixer to low volume for "System Sounds." However the UAC alert sound seems always to be at maximum volume, which is not tolerable. My only solution so far has been to mute System Sounds completely in the volume mixer. At least that shuts that loud UAC sound off. Is this...
Unmountable Boot Volume in BSOD Crashes and Debugging
Hi guys, My windows 8 consumer preview has crashed and gives me the 'unmountable-boot-volume' error. Problem is, I had enabled the fast boot option on my machine using the Toshiba hardware utility, so now i can not access the bios menu and boot from CD/DVD drive as i would have preferred. i cannot...
