Problem with HDMI Audio - Seems to go into a sleep mode
    Win7 Ultimate
    Hi,
    I have Windows 8.1 x64 and the following:
    Radeon HD5450
    Samsung TV connected via HDMI to graphics card
    AMD HDMI High Definition Audio Device
    Realtek HD audio
    I have a strange problem that has not always been there but just recently if I don't have any sounds for about 5 minutes the HDMI audio seems to go into some sort of suspended mode and when I click on (generate) a sound (either system or music etc) it takes about 30 seconds for the sound to actually appear (manifest itself) through the Samsung TV speakers.
    At first I thought it might be some conflict with the Realtek HD audio so I have disabled this (mobo built-in sound) in the BIOS and uninstalled the realtek drivers. This did not help.
    I then thought it was probably an update to the Sound drivers or the graphics drivers for the ATI / AMD Sound card. I have installed the latest catalyst drivers and this did not help. I then fully uninstalled the catalyst drivers including the HDMI Audio and installed an earlier version 9.2.00 from 2012. This did not help either.
    I just cannot get to the bottom of it and wondered if anyone else has this issue or can help.
    The only Playback Audio Device I have in the Sound settings is Digital Audio (HDMI) and I have tried disbling all audio enhancements. This did not help.
    Please note that this happens even if I am using the computer (i.e. the screen can be on all of the time and it still happens after a few minutes).
    Other things I have tried:
    Power Config - disabled Link State Power Management for the PCIe card
    One think I have observed (and I am not sure if this is a symptom or a cause) - The "Windows Audio Device Graph Isolation" process uses about 3-4% CPU while the 30 seconds or so elapses between the sound being invoked and it playing through the speakers. the rest of the sstem is relatively in idle. I can reproduce this by clicking on the sound and adjusting the volume a tad. It is meant to make an immediate "bing" sound to show the sound level is clicked or changed.
    If I wait the 30 seconds then the sound eventually comes and then if I click on it again (or do other sound related things) then the sounds are instantaneous. Its only of I leave it 5 minutes or so with no sound activity. If I wait, say, 2 minutes the sound is instant too so long as their has been a sound event in the prior 5 minutes or so.
    Its driving me nuts!!
    Cheers,
    Paul
    United States
    Windows 8.1 Pro 64-bit
    Is this a home built or manufacturer made computer? I would start by uninstalling all audio drivers and delete if it gives you the option then reboot and let windows do its thing. See if any better. If not, go to manufacturer site and download/install stock drivers.
    Win7 Ultimate
    Hi There,
    Its a home built machine. Been good for ages (at least 6 months with Windows 8.1 (and 4 years with W7x64). Motherboard has latest drivers and BIOS and I have completely uninstalled the Realtek sound (and disabled it in bios) and I uninstalled the AMD HDMI sound and let the catalyst reinstall it with both the very latest drivers and then with the drivers from 2009. On each occasion I uninstalled the old drivers first then rebooted.
    I have also just run latency monitor and this was showing no issues either during a sound event that worked or one of the sound events that take 30 seconds to make a sound.
    Not too keen on reinstalling windows or rolling back windows to a previous time just yet (but I may have to reinstall if I cant get to the bottom of this).
    This is why its driving me nuts.
    Cheers,
    Paul
    United States
    Can't rule out hardware issues either. Could create a restore point then roll back to an older one and see if any difference.
    PS: May be grabbing at straws and nothing to do with it but have you done a sfc /scannow to make sure your system files are good?
    Win7 Ultimate
    Hi,
    Done and SFC /scannow and all was good. I have noticed however that since "downgrading" the graphics and Audio drivers from ATI/AMD/Catalyst to the 2012 version the delay seems to have dropped to about 3-10 seconds as opposed to 30.
    I did also apply Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: June 2014 update from Windows update last night so it is possible this had an effect too.
    Most odd!!!
    Cheers,
    Paul
    United States
    Have you tried the drivers supplied by the MB manufacturer? It's sounding more and more like a buffering problem which could be either hardware or software. The hard disk checks out and memory?
    Found this interesting article: Windows 7 Tuning Tips for Audio Processing | Knowledge Base | Support
    Also found this little tidbit: No Audio or Audio Dropouts when HDMI Audio is Set to Bitstream or Auto : Interdyn
    Win7 Ultimate
    Hi,
    Useful stuff. Thanks for that. Unfortunately my Mobo is a little old and is not officially supported on Windows 8 so no drivers from Gigabyte. I guess its all pointing to a new mobo!!
    Cheers,
    Paul
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel 9.17.10.3040 Playback Devices
Hello, I have a laptop HP pavilion g7 with built in windows 8. I've upgraded to 8.1 from start and now beginning to have some issues. - When i alt-tab between apps and different programs, my left alt-key doesn't work. When i use my right alt, the alt gr button, the alt-tab function works. After...
My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't...
Hi, before I state my problem I just want to clarify that this didn't occur before updating to windows 8.1. Before the update my sound would switch between the tv and the laptop speakers automatically when as I unplug and plug in my hdmi cable. Now, I put my laptop to sleep when not in use or when...
Windows 8 Sleep Mode Problem in Performance & Maintenance
Since my upgrade to Windows 8 Pro from Windows 7, I can't access either the sleep or hibernate feature of my laptop. Whenever I try to go to 'sleep' or 'hibernate', the laptop shuts down after which I have to start it all over again. I did not face this problem with Windows 8 Consumer Review. ...
Am using win 8 RP. When i wake up my lap from sleep mode my keyboard and mouse is in freeze state. am unable to do anything.But my display is working and also function key is working. Before 2 days everything was fine. but now i donno whats the prob.
