No sound from headphone jack
    win 8.1
    title says it, i downloaded the most recent version of the realteck drivers from toshibas site and i have no sound when plugging in headphones.
    Did the headphone jack ever work? Is the headset you are using a known good headset?
    If the unit is still under warranty, best to contact Toshiba. If its a hardware problem (and under warranty) only Toshiba can get it corrected.
    win 8.1
    known working headphones, known working jack (i dual boot linux) its a software (possibly drivers) issue
    I worked an exact same problem recently with another user. They decided to do a new (clean) install of the OS and drivers. I haven't heard back on whether that fixed it.
    Reinstalling drivers, and several other operations failed to fix the issue.
    win 8.1
    as this is a fairly new install (less than 4 days) and the issue started upon installing a windows update is there a way i can remove all audio drivers from the machine and retry? i installed all the drivers on this machine including video and touchpad and this is the only issue. if not is there a way i can preserve my applications through a install like when i transitioned from w7, its really a pain even with ninite.
    As it started after an update, what was the update? 8.1 or 8.1.1?
    Reinstalling, again, is a last resort. I don't like to tell people to just "reinstall" when there are problems. I mentioned the other case because it was exactly the same - worked with Linux but not Windows.
    Two things to try. (1) go to the Device Manager and uninstall the RealTek sound, DO NOT uninstall the drivers, and then restart the PC and when Windows starts it will detect and reinstall the Sound. If there were a corruption between Windows and the sound this will fix that.
    (2), Uninstall the Sound, as per #1 AND the drivers. Restart the PC and Windows will install the generic, basic function, HD Audio Codec. Then try the headphone and see if it works. If it does, try installing the latest HD Audio Codec direct from RealTek as it has the latest Windows 8 drivers. Realtek
    win 8.1
    so looks like the older drivers worked fine and fixed the problem. i did have to uninstall the other drivers but lesson learned. pick drivers that match your model, new is not always better.
Hey guys, I've been looking everywhere for a solution to this: Headphones Working Fine, Mics aren't...But totally no luck. I can see that a lot of people are having this problem and posting it on various forums, without any valid solutions or workarounds. The Problem: Asus Laptop with Windows 8.1...
I have read a number of threads on this issue. My HP running windows 8.1 with IDT High Definition Audio CODEC consistently tells me that my headphones are unplugged in both the front and back audio ports of my desktop. I thought getting windows 8.1 on my new desktop would enable me to have audio....
Windows 8 Headphone Jack in Sound & Audio
This seems to be a pretty common problem. I'm working on my friends computer, because his headphone jack isn't working. He has an Acer Aspire M, with a third-gen i5, 6GB DDR3, Windows 8 64bit, and a Realtek card. He had been using headphones in the side jack, and they were working fine, but...
Solved no sound in headphone in General Support
I am using window 8 (64 bits) Speakers are working fine but there is no sound in headphone
Headphone Jack Not Working in Sound & Audio
I updated to Windows 8 today, and everything seemed to be going well until I tried playing music through my headphones. They worked fine on my iPhone, but once I plugged them into my laptop, no sound came out. Pictures: http://i.imgur.com/QsxifqG.png http://i.imgur.com/eZsVKBe.png I ran...
Hi, I've just got my Windows 8 through Dreamspark Premium. I was using windows 7 and did a clean install of windows 8. After installing windows 8, there's no sound from my speaker. Sound only works with earphones. What should I do? My laptop: Asus N53J **UPDATE** I went to the asus...
