Volume bar at top left corner
    Hi,
    So instead of explaining what I'm looking at right now I'll post a picture here:
    So as you can see that bar there is putting my volume automatically up to 100% every single time I touch it. Also, recently this has made the computer unable to drag the top or side or have any Windows 8 features available this includes both Windows buttons on my keyboard. I have tried cleaning my keyboard as that seemed to work last time on fixing this problem for maybe a month, however it worked for only an hour this time. It also seems note worthy that I cannot capitalize these letters at all: z x c v m , . \ and then I can't capitalize certain letters with certain shift bars so I can capitalize s with my left shift but not my right this happens with many other letters too but the ones I listed above cannot be capitalized at all.
    If you need any more info I can give it to you. mainly (could not capitalize the m and any other letters that I put that are capitalized and said could not be I Google searched for the capital version of it) what I'm asking is how to disable this bar I've searched for answers and even reinstalled my audio as some websites said to do. Is this a problem with my keyboard I'm not too sure. It's a AzzA Gaming keyboard so yeah and it's mechanical keyboard. The computer that I'm using is a custom one I ordered online but if you need I could list the specs. I also run with Realtek and nvidia audio.
    Thanks for any and all help. Hopefully we can fix this problem as it makes things nearly impossible to do on the computer.
    This is obviously not a sound problem (this forum section). Whether its a keyboard hardware problem or something within the PC???
    Post this on a hardware section of this forum, may be best to try and get help.
    Definitely sounds like a 'sticky keys' issue.
    To get you out of a 'sticky' situation, (pun intended!), you could try 'Alt Codes':
    A - Z = Alt 65-90 (either alt key, numeric keypad)
    a - z = Alt 97-122 (either alt key, numeric keypad)
    (I'm not going to list them all individually!)
    (not all alt codes work the same in different environments)
    Quote Originally Posted by Edwin View Post
    I'm not to sure how to use these Alt codes? Is there a website you could guide me to that tells me how to use them properly in a situation such as mine? I tried click Alt + 65 on the keypad and that did nothing and than I click a + z and that did nothing so I'm not to sure what you mean to do here.
    Thanks.
    And could a moderator or someone with the power to move a thread move this thread to hardware as it seems that's where it should be.
    To use 'Alt' Codes:
    - make sure Numbers Lock (NumLock) is enabled on your keyboard,
    - press and hold left Alt key (in most cases you can use either Alt key),
    - enter the Alt code number on the numeric keypad,
    - release Alt key and the character will appear.
    Here is a PDF list of Alt Codes you can download:
    http://usefulshortcuts.com/downloads/ALT-Codes.pdf
    To use 'Alt' Codes:
    How will this fix the problem I have though? If it only creates symbols then how could it possibly get rid of the volume bar or me unable to swipe the screen?
    Try cleaning your keyboard volume keys again.
    When I hold my volume key down I can't drag the screen either!
    Hmm I didn't try that because it's a different kind of key but I'm sure it's worth a try! I'll update you with what happens.
    When I plugged it back in it seems to have worked however this might not last long so if it appears again soon I will update otherwise take this as a solve. I'm gonna give it 2 hours.
My menu doesn't come up. It doesn't come up when I press the Windows button in the bottom left corner either. It only comes up when I press the Windows button on the keyboard. Can someone help me? :cry:
Hi all, When you move your pointer to a left corner you should get either the start page or your open tasks/apps. But it's only working occasionally on my desktop. Is this a known problem, just my computer or just me being stupid? :confused:
How to Enable or Disable Switcher Top Left Hot Corner in Windows 8 and Windows 8.1 This tutorial will show you how to enable or disable the Switcher upper-left hot corner in only your user account in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. When you disable the Switcher...
Today, for the first time, when I started my computer, the icons on the desktop (I use the old-style desktop) had shifted such that there was nothing in the top left corner. And I cannot drag anything up there anymore - there's this blank spot where I always used to keep my "My Documents" user...
Hi, I've had a problem with the app switcher since upgrading to 8.1 and was wondering if anyone has had the same problem. When I hover the cursor in the top left corner when two or more apps are happen, I get small white outlines instead of the small preview images that I used to get on Windows...
Hi, every now and then in Windows 8, an application disappears into the top left hand corner of the screen when they maximise back from being minimised to the bottom task bar. There appears to be no way to recover the application, even if I stop it in task manager and start it again. If I click...
Hi, I have an issue with a white rectangular box appearing in the top left corner of my laptop screen. It covers the icons behind it and renders them 'unclickable'. Nothing happens if the box itself is clicked on. It does not stay on top of other windows, just the desktop.
