No sound from speakers
    Latest version of W8
    This will take a while
    A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here.
    Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones produces "doesn't appear to be plugged in' - they are. See next sentence.
    Potential issues that were checked.
    Check audio device issue not present
    one or more audio services isn't running issue not present
    audio device is disabled issue not present
    I can plug the speakers into a Vista PC and hear music so I know(?) the speakers and cable are plugged in and OK.
    Device Manager>Sound,Video and Game Controls>AMD High Definition Audio Device = device is working properly.
    Using most recent driver - Rollback is disabled.
    I have two sets of audio inputs on the back of my PC. Tried them both (have always used the top ones).
    Someone suggested checking my sound card - don't know how to do that.
    One last thing . . . I found an MS article telling me to disable/enable the AMD. Did that but as soon as I disabled it, it disappeared.
    Which CODEC chip do you have on that MB ?
    Sorry for the delayed response.
    Codec chip? I don't know how to find teh chip or the date.
    Sorry, I meant I don't know how to find the chip or the brand.
    CODEC (COder - DECoder) is chip that transcodes sound between analog and digital format and it's usually marked like that or just plain as sound chip or just sound or Audio in the specifications for MB. My for instance is Realtek ALC892 codec.
    In device manager it can go by "Realtec High Definitions Audio". Those things you have to know to be able to get right driver.
    You mentioned that you have two sets of audio jacks in the back of case, is one of them separate sound card (not the one attached permanently to MB). If that's the case, you may have conflict because Windows can use only one of them.
    OUTSTSANDING!!!!!!!!!!!!
    Codec IDT High Definition Audio - driver 10/12/12
    updated, rebooted, works perfectly.
    Thanks very much
    Quote Originally Posted by Alias View Post
    Thanks very much
    No problem, when something starts to screw up, drivers are first suspects. Many blame it on OS and knowing exactly what HW is and get appropriate ones.
this is my latencyMon screens 54926 54927 please give me steps what should i do
No sound from speakers in Sound & Audio
Hi. Just got my Acer Aspire E5 572g back from repair at Acer Repair Center. They switched out my prosessor, but now i got no sound. The computer came back with a clean install og win 8.1. Added a screenshot showing drivers and that sound is "playing"...
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
Ghost sound/speakers.. in Sound & Audio
Hey guys So this is a weird one... I have a Xonar D2 sound card, and the Xonar D2 Audio Centre, all sound thru my speakers and headphones fine. All music, games, skype are heard and picked up on the D2 Audio Centre just fine. HOWEVER When I open the Volume mixer, almost every program I have...
Well this has gone for a few weeks and I had my laptop for about a year now. The problem is after watching 3-4 videos, the sound will not work on the next file. I tried restarting and it worked! But after another 3-4 videos, there was no sound again. Another thing is when I open a music file, it...
Yesterday, I bought a pair of Samson Studio GT studio monitors. which connect to my computer via USB. However, I'm only getting sound out of one monitor/speaker, that would be the right side with the power cable. I've checked the speaker wires and made sure they were hooked up correctly for...
