Strange audio problem in Windows 8 Pro
    Windows 8 Pro
    So, I've been running Windows 8 for a year, never had any major problems, till now.
    When I'm watching any videos, say a 5 minutes video, I watch 2/3 of them, and the Audio suddenly stops working, at all. There's no sound. Volume bars doesn't show any sound generated, too.
    So, first I thought there was a problem with the Audio Driver, so I reinstalled the driver, which didn't solved the problem. Then I completely un-installed the third party audio driver and relayed totally on the Window's default audio driver (Which didn't had the SRS or other effect, but if this problem gets solved, I don't care about that) but that didn't worked, either, same problem.
    I tried disabling/re-installing the default driver, too. No luck But the problems gets solved if I restart the PC. Restarting takes a few little seconds, but it is really annoying to restart the PC in every hour or so.
    So, as you can see, I've tried most of the general troubleshooting. I guess you people can help me.
    (Note: I really don't want to reinstall Windows)
    How about some system info? Manufacturer and/or MB model #? If applicable, audio card info.
    Windows 8 Pro
    Quote Originally Posted by OldGuyGeek View Post
    Yes. It's not my desktop, but a P.O.S Laptop.
    It's a Dell Isnpiron 5110 which I use to watch shows and stuffs. Has a built in Sound card, I guess.
    windows 8.1 Pro
    Same problem
    I have the same problem except my problem happens when I switch to my tv and then back to my pc is when the sound dies. Then restarting is the only cure. And this is also something new. I am thinking the problem might have come from an update.
A few weeks ago, my audio was in a good condition, and played in perfect high definition. Just recently, all sound coming from my speakers stopped working, and I haven't been able to hear a thing, even with the sound turned 100 percent up. Whenever I press F11 in an attempt to mute the PC, it will...
I'm using my laptop MSI GE60-2OE. When I first boot into the system, everything looks fine 39891 39892 But after using for a while, the display becomes odd. Every item becomes bigger than normal and the entire screen seems bigger than the screen size 39893 Even worse, in the desktop...
Solved Windows Services Very Strange Problem in BSOD Crashes and Debugging
Let me start off by saying that all my services are working fine. However, all the Windows services show this in the 'Description' column "Failed to read description. Error code: 2". Also when I click into any of my hard disks 'Properties' dialogue box I cannot run the disk error check. When...
I have had a strange problem. Occasionally after switching to the lock screen(Win + L), I am not able to type the letter "O" or "L". If my password contains either one of these letters, I am not able to log in unless I use the onscreen keyboard. Anyone has encountered similar problem or...
hey, after i installed windows 8 , there is strange noise , i have to say that i hear ths sound (music/video ) but every 5-10 sec there is electric noise from my speakers. in win 7 everithing was ok i tries to install the new drivers (for win 8) but nothing... helpp pleaseeee
In desperate need of some help here, any advice massively appreciated - I installed windows 8 as dual boot alongside windows 7 on my laptop, (dev build) and having played with it for awhile decided to delete off my hard-drive... (Long story short, formatted whole harddrive yet windows 8 error...
