Crackling noise in any headphones I use. Please help
    When i use my headphones the work just fine for a while but then a crackling, popping noise begins. It happens whether i am listening to audio or not and it has happened with 2 pairs of headphones and a set of speakers that plug into the headphone jack in front of my computer.i have no idea if this is something wrong with the jack or if it is the software. If you have any ideas please let me know. Thanks!
    Quote Originally Posted by baseballkarl View Post
    Is that a Desktop computer ?, did you check in the back panel jacks.
    Yes
    Yes it is a desktop computer i had put together for me at a Tiger Direct store. the jack in the back of the computer worked just fine
    Than the answer is clear, either front jack is faulty or not connected right or wires leading to MB connector are not shielded enough.
    Thank you.
    Ok thank you for your help!
Whenever i plug in my headphones, i hear a buzzing noise. its not the headphones problem, i tested them on other devices and there was no problem. I even changed speakers but i still have the prob, Please Help, ty. :(
Sound crackling/popping in Sound & Audio
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
Hi everyone, I have an interesting problem: On my laptop (Lenovo Y510p) I can hear a buzzing/whistling/noise sound while my headphones are plugged in. The problem goes away when I mute my sound, but this buzzing can be heard while booting as well. This led me to believe that my problem is...
Sound Popping/Crackling in Sound & Audio
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
I have the asus s400ca it has the microphone and headphone in the same jack. My headphones are fine in any other laptop but when I plug them into my new asus I hear very loud static even when playing music. It came with via hd audio and I can specify any other information if necessary, please...
So I just installed Windows 8 and decided to play some music, found out that my DPC Lat is huge and I did try disabling some things such as audio drivers LAN drivers etc. Still didn't solve the problem so I'm at a loss at what I'm supposed to do now. Maybe I skipped over certain parts which I...
Cannot stand the crackling in Sound & Audio
Folks, as you know I am always a staunch proponent of new Microsoft technologies, all the way back to Windows 3.1, but I have never had an issue with a near production OS from them as bad as this. I have a four core with 16GB and cannot get Zune to play w/o popping and making me crazy. I know...
