Windows 8.1 no sound help
    nsw aus
    windows 8.1 32bit
    Hi this is my first post I just upgraded to windows 8.1 today from XP all went smooth but I cant seem to get any sound. The speaker icon in the bottom right of the screen has red cross through it and says no speaker or headphones are plugged in I have tried two different sets of headphones and my surround sound system and still says the same thing. sound was working fine before upgrading from xp
    Drivers, drivers, drivers....
    nsw aus
    windows 8.1 32bit
    ? Should I have posted this in drivers or is that part of the problem I am having?
    Keep checking for Windows updates, important and optional ones.
    nsw aus
    windows 8.1 32bit
    Ok will keep trying and see what happens.
    nsw aus
    windows 8.1 32bit
    Just done 14 updates and still the same still coming up no speaker or headphones are plugged in. when I click on the speaker icon it comes up with a trouble shooter and at the end it says the speaker headset or headphone is unplugged.
    Quote Originally Posted by brendon19 View Post
    First check in Device manager if there's anything for sound or anything Unknown device or with yellow mark.
    nsw aus
    windows 8.1 32bit
    fixed ended up finding a Realtek High Definition Audio Driver for Windows 8.1 from a Lenovo website and it is all fixed now
    here is a link to if any one else has the same problem Realtek High Definition Audio Driver for Windows 8.1 (32-bit, 64-bit), 8 (32-bit, 64-bit), 7 (32-bit, 64-bit) - ThinkPad
    Bravo, hardware can't work without drivers, it's just matter if they are built into OS or not. Check Device manager, you might be missing some other drivers.
Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and...
REALTEK AC97 sound driver installed Working fine!..showing status working but no sound:cry:..after updating PC to win 8..worked well for Win 7..Need Help..:zip:
