Lost audio
    Lost audio
    Tried a search here but found nothing.
    No idea if this is sw or hw.
    My audio has worked well since buying my PC (months). Audio on YouTube worked. Audio on MP3s worked.
    A few weeks ago I lost all audio. The speaker ivon in the task tray has an 'x' over it. When I swlwxct "troubleshoot,' I get a 'peripheral is not plugged in' response. It is plugged in. I can take the audio cables (cords?) out of the W8 PC and put them in a Vista PC. Audio works perfectly, so I presume the cables are good, the speakers are good.
    How do I determine if this is a hw or sw problem?
    Best thing would be to try reinstalling new drivers and if it says "no device found" than...
    Also check in the BIOS if sound is enabled at all.
    Thailand
    windows 8.1 pro,ubuntu 14.04
    right click on the icon in the tray sounds like your sound is muted
Lost audio
Hey, I have had a few problems with the above laptop which appear to be have solved by installed a new pure SSD hard drive. Windows 8.1 has been installed and the OS has activated fine, the only strange thing is that it appears i have lost all audio and the speaker symbol at the bottom right...
MY LAPTOP HP 6121TX I 7 SECOND GENERATION,BUT AFTER INSTALLATION WINDOWS 8 FUNCTIONS WELL,BUT BEATS AUDIO A SPECIAL AUDIO EFFECT OF THIS VERSION OF HP IS TOTALLY LOST...PLEASE HELP:cry: :D:D:D PRESS FUNCTION KEY+B..beats icon will appear in system tray... Right click the icon options comes up...
