Realtek Audio HD x64 drivers, to install or not?
    UK
    I'm running win 8.1 update, from a fresh install and the drivers out of the box run my sound card perfectly well. It does all I need to do even muting speakers when headphones are plugged in. Should I install the downloaded realtek x64 drivers or not. Opinions?
    Edit: Answered my own question I can re-assing rear jacks with the default drivers so had to install the realtek ones.
    Southern California
    Windows 8.1 Pro with Media Center x64
    Quote Originally Posted by banger View Post
    You're re-assing? lol
    Yep, usually better to have the most up to date drivers, if for nothing else but stability of the system.
    UK
    LOL meant to type re-assign hehe.
My microphone volume is really low and has been for a long time, I figured I could install the latest drivers to see if it made a difference since I am just using whatever Windows 8 decided to install automatically. Sound is fine other than the microphone volume. However when I downloaded the...
Recently I did a full uninstall of all AMD Components to do a clean installation of the latest 14.2 Beta Drivers. After that, while installing 14.2; I keep getting this weird message saying that: 38519 It only started after installing 14.2 and I'm even trying to install 14.1...
Hello all, I wasn't sure where to place this FYI; however, I know many are interested in upgrading their old rigs to Windows 8, and since the integrated sound drivers seem to be a problem area, I decided to share my personal experience in the Sound and Audio Forum. So, I upgraded my ancient...
Hey all, I have an Asrock Pro4 Z77 with ALC892, running Win 8 64bit Pro. So I wanted to install new drivers for this audio device and downloaded the R2.70 drivers from Realtek.com and installed them without a hitch. However, when I went to the Asrock website and clicked on my mobo I saw...
Can't install audio drivers in Drivers & Hardware
My computer came with a disk with audio drivers for it, but when I try to install them, it saids that i need to be on win 7. I mean I can hear sound just fine, but without the drivers I can't use my mic. Any help would be nice, and thanks in advance.
Realtek HD Audio 2.68 audio driver download from Guru3D.com To easily install, go to device manager first. Then right click the Realtek audio, choose uninstall and also check the box to delete the driver. This saves you a reboot in the process to install. When you run the installer, it won't...
