TekNMotion Yapster Blaster PC Mic not functioning
    Hello. I have a TekNMotion Yapster Blaster XBOX360/PC headset that I use for my PC, but the mic does not seem to work for my PC. I have tried plugging it in the front jack and the back jack (I have a desktop PC) and I have tried to set it up again via "Set up a Microphone". In Sound>Recording my microphone icon has an empty bar next to it. Under the "Levels" tab in "Microphone Properties" I have "Microphone" set to 100 and "Microphone Boost" set to +10 dB. I am running a Windows 8 PC. This is the empty bar that I was talking about next to my Microphone's icon:
    Do you have proper Realtek drivers installed ? Last version is 2.73.
    Does the plug on the mic have a "TRRS" plug rather than a "TRS" type plug that is required by the PC?
    Here is a picture of a TRRS type plug
    And, here is a picture of the standard 3.5mm TRS plug required by the PC
    Wow, looks like I don't have the latest version installed, but when I try to update my audio devices in device manager, it says there are no updates.
    I do have a TRS plug.
    Driver updates from Windows control panel look at MS driver base only. Here, download original Realtek drivers from here: Realtek
    Now comes bad news, if there's only one TRS plug, and not 2 separate ones, one for mic and another for earphones, than it will not be possible to have both things working, I don't know how Xbox does it but with PC you need separate plugs.
    I tried to download the Realtek driver, but I was told "No devices supported in this package". Also, The headset does have two separate plugs.
My pendrive is not functioning in Drivers & Hardware
4734347344 When I tried to format my pendrive is not working ,it is also showing in hidden.Help to access to my files.
Ive noticed since I installed windows 8.1 none of my apps have been working I figured this is because I left the installer running over night and my laptop might of turned off before finishing the installation so it might be corrupt didnt think much of it at the time since I never really used the...
Constant BSOD and now functioning okay. in BSOD Crashes and Debugging
Just had a loop cycle BSOD earlier with different errors and now working okay, i try to do system image restore but BSOD still there and then use SystemMechanic Pro but BSOD still there and I decided to go with Safe Mode with Networking and do SystemMechanic again but BSOD again and after several...
Recently I installed a fresh, clean install of Windows 8 pro 64 bit on a sony vaio laptop vgn-z540n model, and then did a restoration of Windows settings and files from windows easy transfer (wasn't able to transfer everything though). After that, installed most of the drivers that to make the...
Solved Sound Blaster X-Fi Driver in Drivers & Hardware
On Friday 10/26 I upgraded to Windows 8 Pro and found I still had the SB driver problem for the X-Fi which is not supported by Creative anymore since my system is now over 4 years old. I'm not sure exactly when this original X-Fi card came out. I tried different Creative drivers as I had in the...
