Solved Updating Realtek I lose sound effects tab
Dude
Active Member
Below are the pics when I use the version from my motherboards disc. If I update to any newer version, the sound effect tab disappears. Probably something simple to fix but I went through all the settings it's still gone. I tried installing the latest version from the MSI website, and using the LiveUpdate tool MSI has same thing...no sound effects tab after updating :huh:
    W10 Pro X64
    Dude
    Intel(R) Core(TM) i5-3570K CPU OC@ 4.5 GHZ Turbo
    MSI Z77MA-G45 (MS-7759)
    8.00 GB DDR3 1600Mhz
    PNY GTX 760
    Realtek High Definition
    Dell S23O9W, HP L1710
    DELL-1920 x 1080 HP-1280 x1024
    Crucial m4 256 SSD WD 7200RPM 500GB
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    MSI DS100 Interceptor
    50 down 5 up
    Chrome, IE 11
    Logitech X-620 Speakers
Hi Dude,
The MSI website shows the latest driver version as 6.0.1.7111 but the Realtek website lists an R2.73 package as the latest and it contains driver version 6.0.1.7803 which appears to be latest for Win 8.1 x64. Just in case you haven't tried it yet:
Realtek
Hope this works for you.
SpringUpdate
    Windows 8.1.1 Pro
Hi Dude,
Realtek
SpringUpdate
I will try that one now, thanks mate
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
Well that didn't work. Guess I will stick to "If it works..Don't fix it" Wasted a few hours over a driver update :cool:
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
I suggested the RealTek driver on your Win 7 forum post. If its not working, completely uninstall the RealTek, reboot the PC, and then install the driver from RealTek. I'm using the RealTek driver on both my Win 7 64 bit and Win 8.1 64 bit installations and have the Sound Effect tab on both OS installations. I have two home built systems, one with a Gigabyte motherboard and another with an ASUS motherboard and using the same driver on all.
It is strange. I update using the site from my motherboard and the sound effect tab disappears and I lose my rear speakers. I tried the realtek one and the audio manager didn't even show in control panel.
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
Never mind MB manufacturer's drivers for Realtek, make sure you completely uninstall old ones and try with this driver : Realtek
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I tried that one, same thing no sound effects tab and rear speaker went quiet. I will just leave it on the one I have since it works. Thanks for the link
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
Ok, I just don't know why you are missing sound effects, They screw up my sound and we have same chip. My grandson was playing with settings on my computer, turned up Karaoke setting up and suddenly I had Donald Duck in my computer. It was hilarious to him but not so much for me.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I hear you. It's strange, I had the same thing on a W7 system but got it going. Just don't remember how I did. I even booted in safe mode and used drive sweeper to no avail. Works fine so I should leave it alone, but I know I will try again soon ;)
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
Can's stop tinkering eh ? I'm like that too, will not stop until perfect (or perfectly screwed up).
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Yep, that's me. I got it. Seems that the other sound add on my motherboard offers called sound blaster cinema was the culprit. I uninstalled it and the sound effects tab comes back. :D
Now I can try and figure out how to add it back :confused:
Edit
Never mind, just realized it was now reading my rear channel speakers as side speakers :mad: Back to the 6839 driver again
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
Check the SoundBlaster "enhancement" to the RealTek. It probably has the Effects option. I have the SoundBlaster Advanced MB software enhancement but it doesn't remove the Effects tab.
Thanks, but it doesn't seem to have any settings to change. Not much of an enhancement so I uninstalled it.
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
This bug of mine never went away, but now with W10 it works properly
    W10 Pro X64
    Dude
    PNY GTX 760
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    50 down 5 up
    Chrome, IE 11
