No sound coming from computer (8.1 Pro)
    Malta
    I was working on my computer editing music when suddenly all sound stopped. If I go into the sound mixer from the taskbar there is nothing listed under applications under speakers. If I plug headphones in sometimes Chrome shows up under applications, sometimes it doesn't.
    Right now headphones are not plugged in but Chrome is still listed under headphones and not speakers. Earlier today it wasn't playing music through the headphones either. There doesn't seem to be any pattern for this to happen.
    I have already updated all drivers, restarted the computer multiple times and run diagnostics from Dell's website (the computer is a Dell Inspiron N5110). the audio diagnostic failed at the microphone testing stage and wouldn't let me get any further with the tests. I have even performed a boot-scan with Avast Antivirus to make sure it's not a virus that is messing with my system, but to no avail.
    Any tips would be greatly appreciated.
    Check the Sound devices listing in the Device Manager. What is the status that is shown for IDT HD Audio? Does it show as working OK, or is there an error code (post the code).
    If it shows working OK, RIGHT click on the IDT entry to highlight it and then LEFT click "Uninstall" DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the audio. This fixes any corruptions and hopefully will fix yours.
    Malta
    It says the device is working properly.
    Edit: I did what you said and they're working again! Do you have any idea what might have triggered this? It has happened once before and I thought it was some kind of bug with Skype on 8.1 (which is the program I was using when it happened the first time), but this time I was using Adobe Audition CS6. Luckily it happened after I finished all of the music editing I was doing, or I would have missed my deadline XP
    Thank you so much!
I just bought a Dell Inspiron 17 laptop with Windows 8.1. When I first plug my headphones into the audio jack it works and it's initially silent. However, after I finish playing any sound from any app through the headphones, a static sound constantly comes through them. It doesn't sound like...
I have an HP laptop running 8.1. I did update my computer or I restarted after an automatic update but no sound comes from speakers or head phone jacks. I have checked my drivers and they are working. My sound is not on mute. Any suggestions?
Hi. I have so many problems with windows 8.1 i have seriously no idea where to begin. First one i would like to have fixed is this damn sound, happened to me first time i installed windows 8.1 aswell, and i have no idea how i fixed it. The speakers are set to Quadraphonic, i have tried all...
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
I put in a little GT 610 graphics card about a week ago and everything has been fine since, I get up this morning and now there is the smell of burning dust coming from my computer. I opened up the case, checked the fans, checked all the hardware, checked for burnt items on the motherboard and...
Sound isn't coming out in Sound & Audio
When I tried to play a video on Youtube I couldn't hear any sound coming out. I tried some things, but without any luck. Someone please help.
