Missing sound in speakers after a few videos.
    Well this has gone for a few weeks and I had my laptop for about a year now. The problem is after watching 3-4 videos, the sound will not work on the next file. I tried restarting and it worked! But after another 3-4 videos, there was no sound again. Another thing is when I open a music file, it works again. But the cycle just goes on.
    Acer aspire v5-551g
    Conexant high definition audio
    Sorry I don't know which other details you might need (this is my first laptop).
    What program are you using for the videos? It sounds like that program is not releasing the audio after you exit it.
    I am using VLC player. I also tried windows media player (during the time that there were no sounds for the vlc) but still the same.
    Trying to get some basics. Are you watching the videos on the Laptop's screen or do you have an HDMI connection to TV?
    Try ONLY using WMC, for videos, when the audio is working and see if you still have the problem.
    On laptop's screen. I'll try it later, off to school Thanks!
    I don't know what happened. I just updated from windows 8 to 8.1 and everything went well. So I guess the problem is solved, then
    8.1 is a major update and probably fixed it.
No sound from speakers in Sound & Audio
Hi. Just got my Acer Aspire E5 572g back from repair at Acer Repair Center. They switched out my prosessor, but now i got no sound. The computer came back with a clean install og win 8.1. Added a screenshot showing drivers and that sound is "playing"...
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
Latest version of W8 This will take a while A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here. Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones...
Ghost sound/speakers.. in Sound & Audio
Hey guys So this is a weird one... I have a Xonar D2 sound card, and the Xonar D2 Audio Centre, all sound thru my speakers and headphones fine. All music, games, skype are heard and picked up on the D2 Audio Centre just fine. HOWEVER When I open the Volume mixer, almost every program I have...
Yesterday, I bought a pair of Samson Studio GT studio monitors. which connect to my computer via USB. However, I'm only getting sound out of one monitor/speaker, that would be the right side with the power cable. I've checked the speaker wires and made sure they were hooked up correctly for...
