HPDeskjet
Rotterdam, The Netherlands
    Windows 8 Pro 64-bit, Windows 7 SP1 64-bit, Windows XP SP3 32-bit
    Own build computer
    Intel Core 2 E6600
    Asus P5Q SE Plus
    8GB
    Nvidia GT240
    Creative X-FI Sound Blaster Xtreme Audio
    24" Samsung Synchmaster 2494HM
    1920x1080 [1080p HDMI connection]
    Internal: OCZ Vertex 4 128Gb SSD, 2 x 400Gb SAMSUNG HD403LJ External: 1 x Iomega 2Tb, 1 x Iomega 1Tb,
    Corsair AX750 [750w]
    Corsair Obsidian 550D
    Wireless Desktop 3000 v2.0
    Microsoft Wireless Mouse 5000
    120Mbps download/ 10Mbps upload Cable Connection via UPC Nederland
sounds like music to my ears...but unfortunetally doesn't work for me. from beginning of w8 my card is unvisible. any ideas please?
"setup is unable to detect a supported product on your system. please ensure that your product is properly installed before rynning this setup program..." that's what i get. win7 was ok...maybe i'm wrong somewhere, but...
You could try to install using Compatibility Mode with Windows 7. Other than that, it's just an .inf issue. You could easily edit it to be compatible with Windows 6.2 if you inspect its format. Basically, look to see why Windows 6.2 is not accepting it while 6.1 does. Could be as simple as changing a 1 to a 2.
(Windows 8 = version 6.2)
Also, make sure your hardware id is in the .inf too.
This is for x86. If x64, then you'll have to disable driver enforcement permanently or at boot each time.
Here is an example, based on the February 14, 2012 8.96 Catalyst beta driver from ATI/AMD. This is in the .inf:
[Manufacturer]
%ATI% = ATI.Mfg, NTx86.6.1, NTx86.5.1, NTx86.6.0
In this case, I would edit it to be:
[Manufacturer]
%ATI% = ATI.Mfg, NTx86.6.1, NTx86.5.1, NTx86.6.0, [COLOR=#a52a2a][B]NTx86.6.2[/B][/COLOR]
And then all hardware ids are under this section:
[ATI.Mfg.NTx86.6.1]
So, that could be edited to say
[ATI.Mfg.NTx86.6.[COLOR=#a52a2a][B]2[/B][/COLOR]]
instead.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
sounds logically but i have no .inf file (or i have but don'tknow where). setup stucks on the start with mentioned above message, right click, properties, there is no compability tab. in dev manager there is no my sb card. just seems to be not even existing. i'd like to try out your advise (gman) but have no point to hook. please explain me what's going on
In Device Manager, are there any unknown devices at all? Could you please post a screenshot of it if possible?
Sounds to me like your motherboard bios could use an update to the newest from the manufacturer AND MAYBE a tweak to its settings after.
The first thing of interest here is to get it to show up in the device manager in some shape or form.
Has this card worked recently in another OS like Windows 7?
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
scrshtdev.jpgshould i disable integrated sound in bios?. i'm asking becouse i use it to transfer musik to bedroom: u know, one card is main for making music, second one to listen in bed.
Alright, this should not be too difficult from here. What I would need from you is to right click on that Multimedia Audio Controller. Choose Properties then go to Details tab. Change the dropdown to say Hardware ids. Then copy/paste the results here.
I will find you the correct driver or edit one to hopefully work, if that is not possible.
No, disabling your other audio device is not necessary at all. They both can co-exist happily on the same system.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00
PCI\VEN_1102&DEV_0005&CC_040100
hopefully enough;)
Microsoft had this driver on their server but it is not for your EXACT hardware id so that is why they did not give it to you with Windows Update.
I fixed it so it works for you. Extract my download to a folder.
Right click Multimedia Audio Controller as before in the device manager. Choose Update driver software. Browse my computer. Let me pick. Have disk. Browse.
Now find wdma_emu.inf in the folder you extracted to. Click on it. Hit next then ok and it will install.
Creative.zip
If that alone does not install for you like that, then copy/paste my attachment contents from the below link over the .inf in that above extract folder first:
  • wdma_emu.rar
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
let me pick requirates to click on something from list. multimedia audio controller is not listed, so what should i click on?
Click on have disk now, then browse. Now find and click on the .inf.
If that install fails, then like I said above, patch the .inf with the 2nd download as I've shown to do and try again.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
saying shortly, you are a genious. thanks a lot mate. i got it worked now. imagine that i wanted to come back to 7 just because that issue. thanks again.
btw, all apps linked to sb will work normally? i mean console, etc?
Thanks for the compliment. Yes, everything should work as normal and well.
I am unfamiliar with that hardware, but if you notice missing apps or whatnot that you used to have, you can try installing again from the link in the original post of this thread.
Since it is not meant for you card, it will not touch the driver at all and may go on to install software. Or you could try installing just that particular app inside the download folder if it has it's own setup.exe or .msi file. Or you could even try copying over folder(s) from other operating systems that are working and just try running programs to see if they are able to without even an install.
Just some ideas...
Enjoy!
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
