  1. #81
    Quote Originally Posted by m4tthall View Post
    Quote Originally Posted by Airbot View Post
    June 28, 2012
    X-Fi Beta drivers for Windows 8.
    Creative Worldwide Support
    Did this work for you? I am having problems. The sound isn't working in the RP but it was working for the CP. I have tried downloading and installing from that link as well. I get SBXF_PCDRV_WIN8_BETA_US_2_18_0015A.exe run it (tried admin/compatibility mode) but it just says "Setup is unable to detect a supported product on your system". I know for a fact I have the Sound Blaster x-fi XtremeGamer.
    Any help would be most grateful
    You have a real X-Fi card, not one of the re-labeled Audigy ones, so the drivers ought to work. They did for me.
    I had the Windows 7 drivers released already installed. (I probably used the "troubleshooting" mode to install them.) I installed the Win8 beta drivers over those. Whether that made any difference, I don't know.
  2. #82
    Windows 7-SP1 / Windows 8.1 pro
    I'm having a little trouble with my Creative X-Fi Fatality series card. it seems every or every other reboot the driver does load correctly. It shows that it is loaded, but I get no sound. If I go into device manager and tell it to un-install the card and then scan for new hardware, it will find the card and the Audio will work fine, until a reboot or two later.
    I also dual boot into windows 7 and now when the card stops working in Windows 8 it will sometimes stop working in windows 7, until I again, remove the device and let windows re-add it. The big difference is under widows 7, I can reboot all day and never lose audio. But 50% of the time windows 8 will boot with no Audio.
    I'm using the win8 beta drive and the previous win7 driver (2.1.18 I believe) and it doesn't seem to change. So far I've nevre lost Audio with windows 8 running, just on reboots.
  3. #83
    Windows 8 Professional x64
    Quote Originally Posted by Dalexx View Post
    I am having the exact same problem with my X-Fi Xtrememusic. audio works fine for a reboot or two. then disappears but the sound card is still present in the device manager. when i remove it and re add it it works fine for a reboot or two. Any help with that?
  4. #84
    Ok, I think I've actually seen this issue pop up rarely in Windows 7 as well. The drivers and everything appear to be working, but you still have no sound through the back of your card, yet you can still get audio from the front panel headphone jack.
    Yeah, it does seem to be a bit of a problem with Windows 8 as well, much more of a problem in fact. I can't say that I've gone through many restarts yet, but I had audio after the first restart I know, but then I lost it at some point, I'm not sure when exactly as I wasn't really using programs that used sounds for a few days.
    Anyway, the trick I use to get sound back up and running without reinstalling drivers is to simply launch the creative volume panel/switcher and switch modes. The first switch brings back sound, and then I just return to the mode I was using and away I go with sound again.
    It does seem however that it has a short memory on what your speaker setup is. I have mine set to 5.1, and I have seen it switch to 2.1 a few times on me, but both of these issues are a fairly quick and easy change. Not that we should have to mess with this for it to work, but you have to deal with what creative and microsoft gives us.
  5. #85
    Windows 7 x64
    Quote Originally Posted by HPDeskjet View Post
    The Creative Sound Blaster X-fi Xtreme Audio card works fine in Windows 8. The drivers for Windows 7 work without any problem and the Creative updater and control panel also work as they should in Windows 8. The drivers can be downloaded here for the X-Fi Xtreme Audio card - Creative Worldwide Support > Sound Blaster X-Fi Xtreme Audio
    BETA DRIVERS:
    June 28, 2012
    I'm afraid it's not quite as simple as you put it - as there are documented instances where things are in-fact amiss with x-fi cards (on the software side) and Windows 8. I don't have any problems in Windows 7, but when I was using Windows 8 (RTM, Pro x64) for a few days, I was experiencing the Console Launcher (in Game Mode) always resetting to default upon every Windows restart. At that point, I also lost all sound to my speakers. However, I could still change to Entertainment Mode which did retain my settings, but still, no sound from speakers unless I manually reset all settings in the Console Launcher. This is exactly what is being recorded here: Windows 8 Pro x64 Retail No Sound after Restart Creative X-Fi Titanium HD Driver
    So, yes, the drives may work at first glance, but things are not yet 100% reliable.
    Edit:
    (While using Windows 8)
    Sound card: Sound Blaster X-Fi XtremeGamer
    Driver: SBXF_PCDRV_WIN8_BETA_US_2_18_0015A
    Console Launcher: 2.20.16
    Volume Panel: 2.10.57
    Audio Console: 2.30.09
  6. #86
    Windows 8 x64
    OK...Here is the hardware ID info from my sound card...
    I had sound in windows 7 x64...just completely formatted
    drive and loaded win 8 build 8400...what gives?
    Any fix yet?
  7. #87
    windows 8 pro
    The problem with all X-Fi Cards under windows 8 is that Console launcher can't save your settings every time you reset your system, there's a solution that I' tried it
    on my X-fi XtremeMusic and actually worked, just google "PAX MASTER PCI XFI ALL OS Driver Suite V2.35 Default Tweak Edition" , with some luck you'll be at the forum from PAX Drivers...
  8. #88
    im having the same problem console launcher not remembering setting can u help me how to fix it
  9. #89
    Windows 8 (64-bit)
    I have the same problem
  10. #90
    This is what i have done to get the savings to work on my pc, using windows 8 -32
    Works perfect but i have only tested this on PAX MASTER PCI XFI ALL OS Driver Suite V2.25
    1: Install Windows 8
    2: Disable driver sign
    3: install PAX MASTER PCI XFI ALL OS Driver Suite V2.25
    4: Reboot
    5: Configre the sound settings you want
    6: Turn of the computer
    7: Turn on the computer and see if the changes you made is saved
    8: Reboot the pc (settings sould still be saved)
    9: Turn off hibernate (open cmd as admin and type this: powercfg -h off)
    10: Done!
    Note:-before installing the PAXdriver hibernate must be on
Page 9 of 10 FirstFirst ... 78910 LastLast
I have a Turtle Beach Audio Advantage Micro USB Sound Card. It has S/PDIF Optical Out which works great with my surround sound system. I tried installing the drivers on Windows 8 Pro x64 but it keeps saying "Please plug-in USB Audio Device device!". When I go to Device Manager and manually try...
I have a titanium x-fi pci-e sound card on windows 8 pro. It works fine but I cannot save my own settings for sound card. Whenever I restart the computer it reverts back to default. Is there any solution this odd behavior ? Some people say that they cannot even hear any sound out of sound cards....
