  1. #21
    Windows 7 & 8
    Sorry to threadjack but Im having the same issue.
    Hardware ID
    PCI\VEN_1102&DEV_0005&SUBSYS_00231102&REV_00
    PCI\VEN_1102&DEV_0005&CC_040100
    If you can help me that would be great.
    Btw I have Creative X-FI Fatality Sound Card. I tried using the same files that you posted for Mattfly but it doesn't seem to work. Sorta was hoping that the same file would work =/
  2. #22
    Quote Originally Posted by therra978 View Post
    Hardware ID
    Here is your .inf file. Just download the previous Creative.zip I linked to. Extract it to a folder. Then take the .inf from this post and copy/paste it over the one already in the Creative extracted folder.
    Follow the previous insructions now how to install in the Device Manager.
    Let me know how it goes and if it works. If not, I'll see what I can do.
    Creative Sound Blaster X-fi Xtreme Audio card Attached Files
  3. #23
    Windows 7 & 8
    Wow that was a really quick response!!
    I got a step further last time. It shows the hardware name "Creative X-Fi Audio Processor (WDM)" but its not letting me install the the driver.
    "The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering.
  4. #24
    Windows 7 & 8
    If this helps
  5. #25
    This the first time I've ever seen that type of error and I've done this hundreds if not thousands of times.
    You could try removing the .cat file completely out of the directory and trying again. I'll think of what else might be possible as well.
    Edit: This is a little older from 2007 but you could try this driver. It is for XP and actually intended by the manufacturer for your card. You must use Internet Explorer to get it. You can extract it with Winrar. Then install just like before.
    See how it goes. It might not even go because it's XP driver, but then again, there is a good chance it will:
    Microsoft Update Catalog
    Or yet a third thing you can try with how your machine is exactly now is to place all the .sys files in C:\Windows\System32\drivers
    Place the .inf in C:\Windows\Inf
    Place the .dll files in C:\Windows\System32
    Reboot and hope for the best.
  6. #26
    Windows 7 & 8
    Thanks GMan.
    The soundcard driver is now installed but...
    Only SPDIF output works and now windows 8 keeps freezing =(
    I think I will just wait it out a bit until Creative or Windows update us with drivers that are compatible.
    I was really starting to get a hang of windows 8 too. But having no audio right now pretty much blows.
    Ill check again in a week or so.
    Thanks for all your help. I appreciate it!
  7. #27
    Thanks GMan.
    Ya, sounds exactly like Creative to me for sure. Out of curiosity, are you talking about the XP driver installed now or the one from my Creative.zip?
    You're welcome.
  8. #28
    Windows 7 & 8
    Quote Originally Posted by GMan View Post
    Thanks GMan.
    You're welcome.
    XP driver now
  9. #29
    Thanks GMan.
    You're welcome.
    XP driver now
    If you're feeling adventurous, and this is unlikely to work but no harm in trying, copy all of the .sys files from the Creative.zip (i386 folder) over the .sys files at C:\Windows\System32\drivers
    Do the same for the .inf I specifically made for you to C:\Windows\Inf
    and reboot. Test.
    You could make a System Restore point before doing so in case you want to put it back to how it is now without much troubles.
  10. #30
    Rotterdam, The Netherlands
    Windows 8 Pro 64-bit, Windows 7 SP1 64-bit, Windows XP SP3 32-bit
    Very odd. My Creative Sound Blaster X-fi Xtreme Audio card drivers installed automatically on installing Windows 8 and work fine in Windows 8.
    Click image for larger version Click image for larger version
Page 3 of 10 FirstFirst 12345 ... LastLast
I have a Turtle Beach Audio Advantage Micro USB Sound Card. It has S/PDIF Optical Out which works great with my surround sound system. I tried installing the drivers on Windows 8 Pro x64 but it keeps saying "Please plug-in USB Audio Device device!". When I go to Device Manager and manually try...
I have a titanium x-fi pci-e sound card on windows 8 pro. It works fine but I cannot save my own settings for sound card. Whenever I restart the computer it reverts back to default. Is there any solution this odd behavior ? Some people say that they cannot even hear any sound out of sound cards....
