Windows 8.1 Audio Initialisation Problem
    Hey all
    I just reinstalled a fresh copy of Windows 8.1. Everything works fine, apart from the audio. When I play any sound effect, I hear a small "pop" (when the audio channel is initialised), and then about a 0.5s delay before I can hear anything. By this point, I've missed the first 0.5s of the sound effect, and it is halfway through.
    When the sound effect finishes playing, I hear another small "pop", as if the channel is then de-initialised.
    If I click the sound effect continuously (before the de-initialisation "pop"), it plays fine - once the channel is "open" there is no problem. It's only when it finishes, and I get the second small "pop" sound, that if I try to play it again I get the problem as described. Streamed audio is fine - once the channel is "open" it stays open presumably.
    I've got a Gigabyte GA-890GPA-UD3H motherboard, and I'm using the onboard sound.
    The audio was working perfectly before the reinstall.
    I've run Windows Update, and downloaded and installed the Realtek drivers for this motherboard (from here Realtek) to no avail.
    Device manager looks like this - http://i.imgur.com/LtsEbdD.png
    I've also tried to go to the speaker properties, and disable "immediate mode". There were no enhancements enabled.
    Hope someone can help, thanks in advance for any advice.
    Ok, it was as I expected - there is a 1 second delay when initialising the audio channel, meaning short sound effects and system sounds are missed.
    http://forum.xbmc.org/showthread.php?tid=151635
    I found a utility here which continuously streams a silent sound to the audio in order to keep the channel open. It has fixed the problem, but this is really a massive bodge (workaround), and doesn't really address why the issue started happening after reinstallation when all was previously working.
    Any input welcome.
    You have two High Definition Audio Devices listed in the Device Manager. I can't tell what they are for, but that suggests the generic basic function Windows installed sound driver is installed, along with the RealTek. Disable both of the HD Audio Codec drivers in the Device Manager and see what happens.
    By the way, forum protocol is to not link screen shots or the "My System Specs" to some other site. In the My System Specs, list them direct - see my "My System Specs" for what to do. For screen shots, here is the procedure to post screenshots on this forum:
    CLICK ME
    Hello pal. Thanks for the suggestion, but I already tried that as well to no avail.
    I also uninstalled all 3, and rebooted to allow them to be redetected. All 3 came back again.
    Yeah I was too lazy to type out all the system specs, you can't copy+paste them from CPU-Z for some reason, I thought an imgur link would be fine. I'll change it over.
    The two open audio devices are probably for the audio produced through the video card. Did you install your video card drivers from AMD?
    Not specifically but they've been put on by Windows Update - ATI Catalyst Control Panel has been installed, multi monitor support etc.
Windows 8.1 Audio Problem in Sound & Audio
I recently got a audio technica atr-2500 microphone and it has a headphone jack to listen to what your recording. But I don't think that has anything to do with it. The real problem is my sound is to loud, I would usually keep it on 32 but now I keep it on 8 percent. I have Realtek HD audio as the...
Hi, I've installed Win 8 64bit on my Acer Aspire 8930g laptop, in January. Till recently, the 5.1 sound was ok. A couple of weeka ago, the central speaker is silent, the front left & right speakers are very low, the two back speakers and the sub are ok. I tried un-install and re-intall all audio...
So, I've been running Windows 8 for a year, never had any major problems, till now. When I'm watching any videos, say a 5 minutes video, I watch 2/3 of them, and the Audio suddenly stops working, at all. There's no sound. Volume bars doesn't show any sound generated, too. So, first I...
Video/Audio Problem in Sound & Audio
Hello, Just recently I've encountered a problem in watching a video in my laptop. I have NVIDIA GeForce GT740M, in case if it is related. When I was watching a video regardless of the player; VLC, Windows Media Player, PowerDVD, the video was messed up and hangs in still picture while the...
audio problem in win 8 in Sound & Audio
i have acer laptop v5 431 ,, the audio is dolby advance but after some time the audio quality has gone down and it does not feel like dolby anymore .plz help me . i have reinstalled drivers and windows says that there is some problem and the anhancements need to be disabled .. after disabling...
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
