Default audio changes when monitor in plugged in.
    Windows 8, Kali
    Hey guys. I am having a problem. I use my laptop and i plug it via hdmi into a monitor when I am at home, but i unplug it to take it with me to class. Whenever I plug the monitor in it defaults audio settings to the monitor and not to the laptop speakers, even though the default setting is laptop speakers. I have to change the default every time. I have Intel audio drivers installed (6.16.0.3131). It didn't do this until I installed the Intel drivers. Can anybody help me find the setting to fix this? Thanks.
    The problem is that Windows, in most PC's, will automatically set the default audio playback device from the (PC) Speakers to HDMI when an HDMI cable is plugged in. This is a common complaint and an issue that Windows needs to fix as more and more users now have PC monitors with an HDMI connection and it becomes a "problem" with the sound.
    Only thing you can do is manually change the default audio playback device back to the "Speakers" so you get sound in the PC's speakers.
    Windows 8, Kali
    Hmmmm. I never had it do it before the Intel audio update though, which is odd. I'll keep poking around in audio settings. Basically they need to completely overhaul windows 8 though.
    If it worked differently, there was a "problem" before. Windows (Vista/Windows 7/Windows 8) works, or is supposed to work, the way I described it.
    Windows 8, Kali
    It probably was borked. To be honest I haven't had one stable install of Windows 8 and I'm on my ninth install.
    I have two desktops with dual boot Win 7/Win 8.1 and both are very stable and work without problems. One of the desktops is my recording studio system and my recording studio software (Sonar X3) works perfectly on both Win 7 Home 64 bit and Win 8.1 Pro 64 bit.
    Does Win 8 (or 8.1) work OK when just the basic OS and correct device drivers from HP are installed? Could be some installed application or user tweaking that is causing the problems, assuming there is no hardware problems.
    Windows 8, Kali
    Lol no. Stock with just drivers is horrible too. Bad mouse input due to hardware problems. Touchscreen issues. Graphics driver issues. Bad fan control. The list goes on. Nothing but problems I've had with this thing
    I'm using the Intel HD 4000 video on my i7 3770 CPU and no problems, although I don't use HDMI. Is the HD4400 the correct video for your i5?
    Windows 8, Kali
    Yea it's the 4200u processor. It freezes whenever the fan turns on and the audio becomes distorted.
    That suggests some hardware or power problem.
Page 1 of 2 12 LastLast
I've been getting BSODs a few times a day when I'm not plugged into an external monitor. Sometimes I'll get an artifacted screen or just a random restart. I thought it might be an overheating issue so I took apart my computer and cleaned all the dust out. While it helped temperatures a little, it...
My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't...
My laptop is connected to an external monitor by the HDMI cable. The monitor does not have the speakers but has a headphone jack that connects the external PC speakers. The audio, however, is still from the laptop build-in speaker though the video can be seen from the external monitor. I do not...
I have a Geforce GTX 670 in my system and running the latest WHQL drivers from nVidia. I'm looking for a method of forcing games to load on a specific screen. I play FFXIV:ARR mainly and it has the in game option of selecting which monitor to display on when running in borderless window mode...no...
Hello, Last night I restarted my computer and for some reason when I booted it back up I was not able to use my headsets sound. I went through the settings disabling audio drivers and nothing worked, I also tried to change the default audio device but that wouldn't work either. For some reason I...
I've googled the crap out of this for a week, and can't find a fix... I recently upgraded from W7 to W8, and now my HDMI audio is acting up. I have only ever used my Samsung TV as a monitor. When switching from headset to tv audio I used to click the sound icon and select "set as default" ...
