Default audio changes when monitor in plugged in.
  1. #11
    Windows 8, Kali
    I thought so too but honestly I'm not sure because before the I updated the bios it would just throttle itself and stay around 90c and the fan wouldn't turn on.
  2. #12
    Check the BIOS for options. May be something that needs to be set.
  3. #13
    Windows 8, Kali
    Been in there hundreds of times. There is only one option that says "fan always on" which means the fan runs constantly. I think the laptop has an issue reading the temperature sensor
  4. #14
    If may be more than the BIOS, with what is happening when the fans run.
  5. #15
    Windows 8, Kali
    I'm honestly not sure about anything with this computer. I need it for another four weeks for school and then I'm sending it to HP
Page 2 of 2 FirstFirst 12
I've been getting BSODs a few times a day when I'm not plugged into an external monitor. Sometimes I'll get an artifacted screen or just a random restart. I thought it might be an overheating issue so I took apart my computer and cleaned all the dust out. While it helped temperatures a little, it...
My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't...
My laptop is connected to an external monitor by the HDMI cable. The monitor does not have the speakers but has a headphone jack that connects the external PC speakers. The audio, however, is still from the laptop build-in speaker though the video can be seen from the external monitor. I do not...
I have a Geforce GTX 670 in my system and running the latest WHQL drivers from nVidia. I'm looking for a method of forcing games to load on a specific screen. I play FFXIV:ARR mainly and it has the in game option of selecting which monitor to display on when running in borderless window mode...no...
Hello, Last night I restarted my computer and for some reason when I booted it back up I was not able to use my headsets sound. I went through the settings disabling audio drivers and nothing worked, I also tried to change the default audio device but that wouldn't work either. For some reason I...
I've googled the crap out of this for a week, and can't find a fix... I recently upgraded from W7 to W8, and now my HDMI audio is acting up. I have only ever used my Samsung TV as a monitor. When switching from headset to tv audio I used to click the sound icon and select "set as default" ...
