bluetooth not working
    Click image for larger versionClick image for larger versionhi everyone
    my Bluetooth connection has suddenly stopped working, it says that I am offline, I have tried connecting from
    the Bluetooth menu, (see attached) but their is a red cross over speaker icon, I have turned off the audio sink box
    and then turned it back on (see attached) and the speaker icon goes green but then turns off again
    can anyone please help
    regards calmat
    United States
    Windows 8.1 Pro 64-bit
    First thought would be to uninstall bluetooth then fresh install. You don't provide any detailed specs so kind of hard to help.
    hi popeye
    thanks for your reply.
    My Bluetooth adaptor is an Arcam r-blink
    I am using it on my Acer Aspire with windows 8
    I have taken it out and reinstalled it and my computer finds it straight away, but when I try to pair it says
    OFFLINE.
    The Bluetooth adaptor works fine on my ipad, it pairs instantly
    On the attachments I sent, can you tell me why the audio signal says disconnected
    when I untick the audio sink box and re tick I get a signal for a few seconds then it goes off.
    regards calmat
    Quote Originally Posted by popeye View Post
    hi popeye
    did not receive reply to your answer, can you please still help
    regards calmat
    India
    Windows 8.1, Windows 7, Linux Mint 14
    Laptops usually have a key on the keyboard to turn Bluetooth/WiFi on or off. Is your Bluetooth on your laptop turned off?
    India
    Quote Originally Posted by Arpan View Post
    Sorry, my mistake. What I stated above is impossible!
Bluetooth device is not working in Drivers & Hardware
What to do............Need help...........43115
Bluetooth is not working Anymore in Drivers & Hardware
Greetings to all, I have been running win 8.1 for a while. At first Bluetooth was working fine. Then last week Bluetooth stopped working. Why, I have got a clue. What I did is just reinstall the drivers from ASUS web site but to no avail. I have looked at 'Event Viewer' but there is no error...
Windows 8.1 Bluetooth not working in Drivers & Hardware
Hi all, I have just got a nearly new Toshiba laptop and updated to Windows 8.1. Since then I have been unable to connect any device to it via Bluetooth. It was able to see the devices and try to connect but as soon as it connected the connection was dropped and the devices reported failed...
Hi, i cant use Bluetooth since i updated to 8.1, before updating i had my wireless mouse working and my iPod playing through my computer since updating they both wont connect not error just wont connect i tried updating the drivers but their all up to date.
Hey guys, I just got this fancy new usb bluetooth v4 dongle! Nice. Now, when I plug it into my win8 desktop it installs the microsoft 2006 drivers and everything is okay, it works perfectly. However when I plug it into my win8 laptop (both are win8 pro) it installs the 2006 driver but says this:...
MSI GX660R Bluetooth not working in Drivers & Hardware
Hi there, Have recently upgraded to Windows 8 but am finding that my bluetooth functions no longer work with the Windows 7 drivers. When I turn on the bluetooth, it shows up in device manager, states the drivers are installed and functioning ok but does nothing. I get no notfication in the...
Bluetooth not working in Installation & Setup
im using Dell N5110 my bluetooth is not working i have install all kind of bluetooth 2758. PLEASE HELP ME
