Problems with sound recording
graverholt
When I record sound from CD, Website etc. (with Audacity or other software) it records the sound via the computers loudspeaker and from that via the computers microphone.
But I want to record the sound directly from the sound card (or whatever it is).
I know its possible, I have done it befor. But I have reinstalled my pc, and now I cannot remember how to do it.
Can someone help me?
    Windows
    Lenovo
You need the Stereo Mix (could be called System Mixer) in the Sound Panel, recording section.
Go to the Control Panel/Hardware and Sound and finally the Sound Panel. Click on the Recording Tab. The Stereo Mix should be shown and set as the default recording device. If the Stereo Mix is not shown, RIGHT click in an empty space in that panel and then click to Show Disabled and Disconnected devices. Stereo Mix should now show up and you can enable it and make it the default recording device. There are a few PC's without this capability, most have it.
See my screen shot:
In addition to fireberd's suggestion, if you are trying to use Audacity to record sound (directly from the source over the internet), you must set the option as shown in the image below:
Hope our information is helpful.
my2cents
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Thanks A LOT to both of you, it works!
my2cents, seems like you know Audacity. Mine has begun to show/monitor the sound level with a delay of app. ½ sec. Do you know where I can change that?
    Windows
    Lenovo
Hmm... I don't know it that well. Can you show us a screenshot of what you are looking at? Could it be due to a slow (or buffering) internet connection? Mine is 56/11 (down/up respectively).
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
During recording you see like a wave running over the screen with varying height, depending on the loudnes. And this indicator is deláyed about ½ second, also when i record from a cd.
The red vertical line shows "where we are", and you can see that the wave come a little after it.
It's not a big problem, just look strange, and it was correct earlier.
    Windows
    Lenovo
A screen shot won't help you. During recording you see like a wave running over the screen with varying height, depending on the loudnes. And this indicator is deláyed about ½ second, also when i record from a cd. It's not a big problem, just look strange, and it was correct earlier.
Ok, thanks for responding. Unfortunately, I have never experienced the issue you are describing, and since a picture won't help me (per your advisement), I don't know what else to suggest at this point. Good luck from here. Hope we were able to help a bit.
my2cents
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
I thought I had removed "A screen shot won't help you", and as you can see, I have uploaded a screen shot, which shows the problem. But it's not a big issue at all, just annoying.
But you helped me solve the big problem, so thanks.
    Windows
    Lenovo
I have a recording studio (using Sonar X3) so I don't use Audacity either, although it is a good audio recording program.
I notice you are recording at 32 bit. 16 bit is "CD Quality" and all that you need. Having to convert the 16 bit audio to 32 bit may be causing some of your delay (latency). If you were to burn a CD of what you recorded, at 32 bit, it would have to be converted to 16 bit to burn an audio CD.
I don't see any 1/2 second delay so I'm missing something here; however, what I do see is that your recording level is exceeding the current scale setting of Audacity. Now, you can approach this in two different ways:
1. Increase the scaling in Audacity
2. Turn down the volume on your speakers a bit.
This is my last response so no need to respond back because I'm out of ideas. Good luck.
my2cents
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
y not try lowering the amplification?
    Windows 8.1 Pro Update 1
    Dell
    Inspiron 530S
    64Bit X64 based Processor
    4.5GB Ram
    1GB - XFX ONE ATI Radeon HD 5450 - Plus Edition
    Inbuilt
    Dell Monitor
    1440*900
    1*Seagate 150gb + 1*Seagate 320gb
    3 x fans
    Dell Analog
    Dell USB Mouse
    1Mbps, 100kbps Download Speed
    Kaspersky, Norton, Avast, Bitdefender, but Switched off
I just did a test recording with Audacity. The red line in mine is ahead of the actual recorded waveform. What you are seeing is correct (normal).
Problems again
See my screen shot:
Now I can only see Headset Microphone and Microphone 2 times - no matter what I try :shock::shock::shock:
    Windows
    Lenovo
