Problems with sound recording
  1. #11
    Windows
    Look at the red line.
  2. #12
    India
    Windows 8.1 Pro Update 1
    y not try lowering the amplification?
  3. #13
    I just did a test recording with Audacity. The red line in mine is ahead of the actual recorded waveform. What you are seeing is correct (normal).
  4. #14
    Windows
    Problems again
    You need the Stereo Mix (could be called System Mixer) in the Sound Panel, recording section.
    Go to the Control Panel/Hardware and Sound and finally the Sound Panel. Click on the Recording Tab. The Stereo Mix should be shown and set as the default recording device. If the Stereo Mix is not shown, RIGHT click in an empty space in that panel and then click to Show Disabled and Disconnected devices. Stereo Mix should now show up and you can enable it and make it the default recording device. There are a few PC's without this capability, most have it.
    See my screen shot:
    Now I can only see Headset Microphone and Microphone 2 times - no matter what I try
Page 2 of 2 FirstFirst 12
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
For all of you experiencing a sound lag while trying tomonitor a live recording in Windows 8, all this talk of updating drivers andtweaking what not is pure B.S. I havedone extensive research on this issue that first reared its ugly head with the onsetof window 7 (the problem did not exist in XP...
8.1 sound problems in Sound & Audio
Updated to 8.1 and had the dolby problem like everyone. I am not that good with these new fangled machines but how do I fix this problem. The sound is now terrible and I have it all the way to the top and can barely hear anything. Is there a fix that is available or do I need to go back to regular...
Sound with Fraps: YouTube (if you turn the sound up, the problem is much more noticable) Sound with Emulator's recording software: YouTube As you can see, the audio with Fraps feels like it has a bit of distortion to it, and the problem is, while I can record this game without a problem with...
Solved Problems with Sound in Sound & Audio
Okay, starting from the more recent beginning, I decided to upgrade my computer. I installed a new gpu and cpu successfully, but failed to correctly install the power supply. While trying to start the power supply, it shorted and fried my hard drive. After a few painful weeks with best buy, they...
