rear speakers not working
    all plugged in
    new computer
    drivers up to date
    set to quadraphonic
    they were working yesterday but they appear to have stopped on their own.
    the test speaker option worked at first but now they dont
    when i click the speaker icon to test on the sound playback options tab the level indicator shows green as though they are working but there is no sound coming out of the rear speakers
    is there some extra setting im missing?
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    Double check the audio cables going from the PC to the speaker central amp. Also check that they are set to quadraphonic in control panel > sound. Select speakers from the list and click Configure. It's the same panel shown on the left in your screen shoot.
    Quote Originally Posted by alphanumeric View Post
    it seemed to be a realtek setting. when i unplugged and then plugged the speaker back in a second list of check boxes appeared and i tried checking off rear speaker out they came back on. i could have sworn i already had this checked off but some other setting i messed with must have changed it.
    Stuff like that happens sometimes. Windows can switch it to just the two and so can the RealTek software. It never hurts to check both places. You got it working so all is good, for now.
    now it seems like only background noise is coming out of the second set of speakers. is there a way to make all speakers play the same sound? i already tried toggling the speaker fill option on and off and that didnt fix it. only the test option seems to make any significant noise come out of these speakers.
    Speaker fill is how I did it I think. One of my speakers died so I'm back to just stereo.
    Try setting to 5.1 or.7.1 .some streams can't differentiate good enough. I technically have quad ( 2 times stereo but with woofers incorporated in each set ) and some movies used to play only background sounds on one set (like music and sound effects) and front only speech until set to 7.1. Speakers not plugged in will be grayed out.
    Surround Speakers set to On.
    i tried everything, all that comes out of the second set of speakers is static and the test noises
    still having problems with this
    there is some sound coming out but only on certain music and its echoed and delayed
    there are no "effects" on except for speaker fill. it sounds like background stuff and i want all speakers having the same sound
    now i am also having problems opening the realtek audio manager, i cant figure out how to open it.
    If you are hell bent to have rear speakers running too and don't care about separate controls for them, you can use an audio splitter " http://www.radioshack.com/product/index.jsp?productId=2272476" like this as a stop gap measure. It will give you exactly same sound front and back.
Page 1 of 4 123 ... LastLast
Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/driver cauze its only supports side speakers in 5.1 surround sound. If i dont install...
So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and...
Hello all, I've had my laptop for just over 6 months now and I've encountered no problems until recently. However I am experiencing problems with the sound. It just doesn't appear to be working, despite the volume being turned up to the max. The problem usually fixes itself briefly after a...
Right, i've been having this problem since I THINK starting to use a HDMI wire. But now, i cannot get any audio from the audio jacks, they are detected, but no sound is produced and I just cannot figure it out. I've disabled the HDMI, installed, un-installed, re-installed audio drivers and pretty...
Solved Rear usb ports non responsive in Drivers & Hardware
HI, I have problem that just crept up, my rear usb ports are malfunctioning. when I plug my mouse in the light underneath it comes on, but the mouse is not operational. The keyboards numlock light doesn't even go on. My front ports are working now, but this is greatly inconveniencing me...
And it happens only when I boot the computer up and find that neither my keyboard or mouse are working then I plug them into front (2) avaialable usb ports and they work fine.... And then If I try to uninstall universal bus controllers by device manager then my keyboard + mouse stops working...
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
