rear speakers not working
  1. #31
    W10 Pro X64
    Try the older drivers from here
    Index of ./ftp/Mainboard/Drivers/Audio/
  2. #32
    Quote Originally Posted by Dude View Post
    i unzipped both to the desktop
    first tried updating from disk :7102_PG380_VISTA
    same problem after the restart. now its saying they are up to date when i try the other set from the second zip, file "hd"
    should i uninstall and run the executables from these zip files?
    i dont know what will happen if i uninstall realtek completely
  3. #33
    W10 Pro X64
    Yes, uninstall the old ones and try to install from the exe from the zip file
  4. #34
    same thing. the only sound that comes out is the test noises
  5. #35
    W10 Pro X64
    Sorry to hear that. I am out of ideas for you.
Page 4 of 4 FirstFirst ... 234
Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/driver cauze its only supports side speakers in 5.1 surround sound. If i dont install...
So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and...
Hello all, I've had my laptop for just over 6 months now and I've encountered no problems until recently. However I am experiencing problems with the sound. It just doesn't appear to be working, despite the volume being turned up to the max. The problem usually fixes itself briefly after a...
Right, i've been having this problem since I THINK starting to use a HDMI wire. But now, i cannot get any audio from the audio jacks, they are detected, but no sound is produced and I just cannot figure it out. I've disabled the HDMI, installed, un-installed, re-installed audio drivers and pretty...
Solved Rear usb ports non responsive in Drivers & Hardware
HI, I have problem that just crept up, my rear usb ports are malfunctioning. when I plug my mouse in the light underneath it comes on, but the mouse is not operational. The keyboards numlock light doesn't even go on. My front ports are working now, but this is greatly inconveniencing me...
And it happens only when I boot the computer up and find that neither my keyboard or mouse are working then I plug them into front (2) avaialable usb ports and they work fine.... And then If I try to uninstall universal bus controllers by device manager then my keyboard + mouse stops working...
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
