rear speakers not working
  1. #21
    W10 Pro X64
    Okay, what are your complete specs?
  2. #22
    Quote Originally Posted by Dude View Post
    im not exactly sure what specs youre looking for
  3. #23
    W10 Pro X64
    The specs I was asking for can be found by going to your user control panel, then on the left click edit system specs.
  4. #24
    i dont see anything that says system specs in my control panel
  5. #25
    W10 Pro X64
    At the top of the page is user cp
    Then on the left click edit system specs, looks like this
  6. #26
    mines blank, that looks like something i have to fill in myself.
  7. #27
    W10 Pro X64
  8. #28
    i almost want to plug in my old hard drive that runs windows 7 because im just about sick to death of windows 8 and its only been about a month.
  9. #29
    W10 Pro X64
    There is a learning curve going to 8 from 7, In my opinion 8 is better. Take your time and work through any issues you have, you will end up happy. I really want to help you with the speaker problem. I had problems too but fixed them. We can get you fixed too with patience
  10. #30
    what did the specs tell you
Page 3 of 4 FirstFirst 1234 LastLast
Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/driver cauze its only supports side speakers in 5.1 surround sound. If i dont install...
So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and...
Hello all, I've had my laptop for just over 6 months now and I've encountered no problems until recently. However I am experiencing problems with the sound. It just doesn't appear to be working, despite the volume being turned up to the max. The problem usually fixes itself briefly after a...
Right, i've been having this problem since I THINK starting to use a HDMI wire. But now, i cannot get any audio from the audio jacks, they are detected, but no sound is produced and I just cannot figure it out. I've disabled the HDMI, installed, un-installed, re-installed audio drivers and pretty...
Solved Rear usb ports non responsive in Drivers & Hardware
HI, I have problem that just crept up, my rear usb ports are malfunctioning. when I plug my mouse in the light underneath it comes on, but the mouse is not operational. The keyboards numlock light doesn't even go on. My front ports are working now, but this is greatly inconveniencing me...
And it happens only when I boot the computer up and find that neither my keyboard or mouse are working then I plug them into front (2) avaialable usb ports and they work fine.... And then If I try to uninstall universal bus controllers by device manager then my keyboard + mouse stops working...
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
