Cancelling out background noise
    Hi, I occasionally play on my laprop in my front room with my family however when I'm on skype to my friends they can hear my TV and Family louder than I can! Is there any software that can lower the levels of background noise or any tips on how to make it so it's quieter for them?
    Joisey
    Windows 8.1 consumer 64 bit
    You need a noise canceling microphone.
    I doubt you have Realtek sound card but it's drivers have, Noise Suppression, Acoustic Echo Canceling and Beam Forming (directional recording) settings, Check your drivers, there might be something similar. Also see if there is Microphone Boost settings somewhere and lover it down.
Solved Background Noise in Skype. in Sound & Audio
Hi, I've used Skype for the most part without problem since it took over from Messenger. Following recent Skype updates the person I'm connected to receives a rapid repeated sound like a demented Woodpecker which stops while he speaks but starts again when he stops speaking. I can't hear this...
Solved strange noise from PC in Drivers & Hardware
About 2 days ago i opened PC case to do my regular maintenance of dusting inside. Usually use Compressed air. Have 2 case fans (1) 92mm (1) 80mm plus the CPU Cooler fan, my Graphics card has dual fans. Just other day and this only happens when i am booting the PC, i hear what sounds like and...
When i use my headphones the work just fine for a while but then a crackling, popping noise begins. It happens whether i am listening to audio or not and it has happened with 2 pairs of headphones and a set of speakers that plug into the headphone jack in front of my computer.i have no idea if...
Bad noise on quite new laptop. in Drivers & Hardware
Hi, I hope somebody can give me an opinion from his experience. This laptop is 4 months old, Asus X501A. I had to return another one to Amazon because it made some bad clicking noises and the hard disk was faulty as Hard Disk Sentinel said it was with 68% health new. So, this laptop model might...
Specs: Gpu: GTS 450 CPU: Athlon 975 3.6 BE Hdd: WD1002FAEX 1tb Ram: corsair vengeance 4x2 600w psu Windows 8.1 64b Okay so today my PC was working totally fine until I decided to finally put risers on my motherboard (also known as standoffs). I had to remove everything and put it back...
Irritating buzzing noise in Drivers & Hardware
Seem to be plagued with problems at the moment. Have just fixed one and now the Sandy Bridge is making a fairly loud buzzing noise a bit like a doorbell being pushed. It is fairly intermittent and the sound lasts for a few seconds or for a minute or so. It doesn't seem to be related to anything I...
HDD locking noise? in Drivers & Hardware
I've recently just updated my BIOS on my asus laptop to fix my "ACPI.sys" problem but now, whenever I plug an external USB drive in, or do a hybrid shutdown my hard drive makes 2 loud-ish locking kinda noise (similar to when I turn on my laptop), i'm guessing its the HDD head parking... Should I be...
