No Audio coming from speakers and headset at the same time
    8.1
    Hello,
    I just bought a new pc and received it today, and i plugged my headset in to check if i hear audio from both speakers and headset but its not working. When i plug my headset in i only hear audio from my headset and not the speakers. Ive been googling and found something about it but with the newest realtek hd audio i dont have the Playback Device there, only the Recording Device. In this picture it has both the playback and recording device.
    In the Playback Device section of the panel you have displayed. Check the Make front and rear output devices playback tow different audio streams simultaneously and see if that does it for you.
    The usual default mode on PC sound cards is to mute the speakers when a headset is plugged in.
    8.1
    No, i said i dont have that 2 options in playback devices, only the 2 options from recording devices.
    Im sorry if i stated otherwise.
    That's just a picture i found in google xD
    You haven't stated what your new PC is. Some PC vendors will customize the audio for whatever they want. I would first check with the PC vendor for any updated sound drivers.
    No guarantee but the direct from RealTek, IF THAT is what your sound hardware is, should install the panel you show with the correct options. But, first check with the PC vendor.
    Download the HD Audio Codecs, for either 32 bit OS or 64 bit OS -whichever is appropriate for your system.
    Realtek
    8.1
    PC Vendor as in the company i bought the PC from? xD
    I have realtek it was already installed on the PC.
    PC Vendor would be something like ASUS, HP, Dell, etc and the model number. If you fill in the "My System Specs" we will get all the info. Helps us help you.
    As I noted, no guarantees, but install the Realtek driver I have linked and see if that gets you what you want.
    8.1
    I have an asus
    OS 8.1
    nvidia gtx 760
    8 GB ram
    intel core i7-4771 CPU @ 3.50GHz
    That's getting better. What is the ASUS model number?
    @ Kayoru:
    You have any of this in your Control Panel?:
    Attachment 39563
    8.1
    Quote Originally Posted by Edwin View Post
    @ Kayoru:
    Attachment 39563
    No i do not have that, this is my realtek hd audio manager.
    I think its this: ASUSTeK COMPUTER INC. H87-PLUS
Page 1 of 3 123 LastLast
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
Headset / speakers conflict in Sound & Audio
Hi there! I've just finished building my first PC, but I have some sound problems. I want to have my speaker set as the main audio output, so I've plugged it in the back of the PC, in the audio outlet of the motherboard (Gigabyte G1.Sniper B5). But when I play a game, I want to use my headset,...
Hello, I recently upgraded to Windows 8. Previously on Windows 7 I was able to switch between speakers and USB headset on the fly by clicking "set device as default" in windows sound options, without closing media player. Now that I'm on Windows 8, I can't do that anymore: whenever I make...
I'm in the market to buy a headset for chat in online gaming, at the moment game sound is through my gtx cards hdmi to my tv speakers and I want the headset for purely just voice (like Xbox). In layman's terms how would I set it up this way? A friend said he thought the game sounds as well as...
Hey guys. I've been having an issue with Mumble on Windows 8 RP. If I set the audio to come out of my Logitech USB Headset speakers it prevents audio from the mic and speakers. However, if I have it coming out of my onboard audio speakers I can use the headset's mic and everything is just fine. Is...
