No Audio coming from speakers and headset at the same time
  1. #11
    Edwin, the user has the newer RealTek HD Audio Manager. I have the same manager on my desktop with an ASUS motherboard.
  2. #12
    8.1
    soo, i posted the motherboard type.
  3. #13
    There are several (at least 4 that I found) different models of that H87 Plus motherboard.
  4. #14
    8.1
    Well its says thats the one. I used CPUID to find it
  5. #15
    There are 5 that I found just trying to do a google search.
    H87M-E
    H87M-Pro
    H87i-Plus
    H87M-Plus/CSM
    H87m-Plus
    Whether they all use the same basic hardware?????
  6. #16
    Download and run the free Speccy system information tool. It should give you more info.
    Speccy - System Information - Free Download
    Here is the screen shot of my Speccy:
  7. #17
    8.1
    This is mine, it still says the same xD
  8. #18
    According to ASUS, for this motherboard, the RealTek has the hardware for jack reassignment.
    If you haven't done it, download the direct from RealTek HD Audio Codecs driver, R2.73 and install that. See if it will get you the needed capability.
    Realtek
  9. #19
    8.1
    I just installed it and its still the same for me. Nothing changed. D:
  10. #20
    If just installing over top of the existing drivers, there is a possibility it isn't changing anything.
    Try this, go to the Device Manager, uninstall the RealTek and the drivers in the Device Manager. Then restart the PC and when Windows starts it will reinstall the sound, but because the drivers have been uninstalled it most likely will install the generic basic function HD Audio Codec drivers. Then install the downloaded RealTek drivers and if you are lucky it will add the function you want.
    If it still does not have the speaker option, then its been disabled by the PC vendor and in that case you will not have that function.
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
Headset / speakers conflict in Sound & Audio
Hi there! I've just finished building my first PC, but I have some sound problems. I want to have my speaker set as the main audio output, so I've plugged it in the back of the PC, in the audio outlet of the motherboard (Gigabyte G1.Sniper B5). But when I play a game, I want to use my headset,...
Hello, I recently upgraded to Windows 8. Previously on Windows 7 I was able to switch between speakers and USB headset on the fly by clicking "set device as default" in windows sound options, without closing media player. Now that I'm on Windows 8, I can't do that anymore: whenever I make...
I'm in the market to buy a headset for chat in online gaming, at the moment game sound is through my gtx cards hdmi to my tv speakers and I want the headset for purely just voice (like Xbox). In layman's terms how would I set it up this way? A friend said he thought the game sounds as well as...
Hey guys. I've been having an issue with Mumble on Windows 8 RP. If I set the audio to come out of my Logitech USB Headset speakers it prevents audio from the mic and speakers. However, if I have it coming out of my onboard audio speakers I can use the headset's mic and everything is just fine. Is...
