"Audio Output is disabled"....but it's not?
    Hi all,
    I'm at a loss....trying to fix a almost brand-new Acer laptop for friends of mine. They were having issues with music files not playing at all in Windows Media Player or other audio programs, so I told them I would help them. First I thought it may be the sound drivers, so I uninstalled the sound drivers from the Device Manager and restarted, expecting Win8 to autodetect and install at least a basic driver (the system has a common Realtek chip)....nothing happened and no sound would play.
    I then tried updating their audio drivers to those from Realtek's own site as they were newer than from Acer's own site. After restarting, the computer claimed at the bottom left in the System Tray that the "Audio Output Device" was disabled and no sound would play at all. I checked every place I could think of in the Control Panel and the Device Manager, NOTHING is disabled anywhere. I even DISABLED and RE-ENABLED everything I could find in case that would help. Nothing...same error in the SysTray and no sound playing at all. Then I completely removed the updated Realtek drivers, downloaded the latest drivers I could get from Acer's own site and tried installing those....upon restart, same thing...same error in the SysTray and no sound playing at all. Even though EVERYTHING I can find in Control Panel and Device Manager says the device is "working properly" or enabled, the System Tray is still showing as disabled and no sound can be heard from anything.
    I have no idea what the heck is wrong....any suggestions? I also can't do a System Restore Point as System Restore was apparently disabled on this machine up until now...
    Thanks for any help!
    7601.18247.x86fre.win7sp1
    Hi,
    You're not the first complaining of this. Realtek drivers are very solid for the most part, and there otherwise is no reason for this to happen.
    Because of those things, I suspect malware and maybe even a poor 3rd party antivirus as the cause.
    I would uninstall any 3rd party antivirus, use the removal tool for it after, then set Windows Defender and Windows Firewall to Automatic and start them too.
    Uninstall any "junk" software such as system optimizers, RAM "enhancers" and the like. Ccleaner is good to keep if that is on there.
    Scan with Malwarebytes and ADWCleaner.
    You should also check services.msc to see if the two Windows Audio services are set to Automatic and started.
    If the Device Manager shows that the driver is not installed well after your efforts, let me know and I'll tell you what you should do to proceed.
    If you find malware, then really, the machine should have Killdisk used on the hard drive and then clean install Windows after.
    Thank GOD I'm not the first....I'm a tech. myself (although probably not as advanced as you...), but this is the first time I'd ever dealt with this and checked everything I would usually check that SHOULD fix the issue and nothing worked! I felt VERY embarrassed and frustrated with myself as my friend was present and I felt bad having to send her on her way with a laptop with no working sound....plus I KNEW I was doing everything that should've fixed the issue normally and when it wouldn't work I could not think for the life of me, why it wasn't solving the problem!
    I don't have it with me, but the next time I will have it in my hands to look at is Monday. It's a brand-new Acer Aspire laptop, can't remember the model (i.e. a month old) - I don't recall what Antivirus it had on it (I seem to think either AVG Free or Avast Free...? I know they are both good AV software....I've personally used both), but there was nothing to suggest there was any malware (i.e. nothing acting oddly except the sound issue). If I can't solve it, I'll run a Malwarebytes scan at least to see if it finds anything.
    Device Manager WAS showing the drivers were installed properly and as far as I could tell, everything was enabled properly...there's ONE thing I might've missed (I was in a rush) and I e-mailed them about it 5 mins ago. Hopefully they'll try it on their end and get back to me soon. Either way, if what I suggested to them doesn't or DOES work, I'll get back to you folks regardless and tell you of the outcome / be asking for your further suggestions!
    Thanks for the quick reply mate!
    AVG and Avast have had more than their fair share of problems, for sure. Yup. I have some tricks if needed too.
    Quote Originally Posted by MasterChief View Post
    Is this only regarding Windows 8? I've used either on Win7 and WinXP for years with no problems whatsoever!
    As for an update on the situation, no response from her about trying what I suggested yet....will again post when I found out if it worked or not...
    Quote Originally Posted by darkstrike View Post
    No.
    Literally, that phrase is said to me ~5 times a day on average. I fix BSODs here and have been on various sites for many years. I almost put it in my signature and actually did yesterday, but removed it.
    Speaking of AVG - it is very fair to say that it holds the world record for causing most stop errors because of when it had a long stretch during 2009-2010 for Windows 7/Vista/XP.
    Ended up having to do a factory refresh, so crisis averted.
Hi, I purchased an HP Notebook PC 2000-2c20NR last week that came pre-installed with Windows 8. Somehow - I think it was when I was trying to change settings to where I do not have to give a password everytime I log in - I became lost as the Administrator. I am the only one who uses this laptop....
I disabled UAC through HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\System\EbableLUA=0x00. I don't care about being unable to run the MS Apps, but I want to run programs like Acrobat. Win 8.1 won't let me run Acrobat by double clicking a PDF, although I can open it from a shortcut. ...
I don't know what I did, but all the background images on all websites (including this one) are gone...if I right click on the web page, the selection "View Background image" is greyed out, disabled. Does anyone know how to reset the background images on websites so they appear again...I would...
Solved IE10 "Metro mode" disabled? in Browsers & Mail
My IE10 seems to have its "Metro mode" disabled. I can't seem to use it. The Internet Explorer tile in the Metro Start Menu just brings me to desktop and opens IE (in the desktop instead of opening it in Metro). I barely recall it was working (goes into Metro when opened in the start menu) when...
