Realtek audio manager completely missing
    Hi I need help, can't find a solution and this is slowly driving me crazy...
    I installed the realtek drivers and they appear as installed in the control panel but it does not show up at the start up of windows, I have tried installing the latest drivers from realtek official page and the lates of my motherboard (ASUS P8 H61-MX) but they just do not work propertly, audio manager is missing, it is nowhere in the task bar or at the panel control nor in "Sound"
    This is what I do not have and what I want, please help.
    Thanks.
    When you go to Control Panel and View by: Large icons, "Realtek HD Audio Manager" is not there?
    What do you have listed in the Device Manager, Sound section?
    This is what my RealTek HD Audio Manager looks like
    Quote Originally Posted by Edwin View Post
    It is not, nowhere.
    I do not have any audio manager, this is all I have (I am spanish, hope you understand) Click image for larger version
    Is this the file version you installed?
    Attachment 38506
    Well, according to the MB specs, you have this sound codec : "VIA Vinyl HD Audio codec" so you need drivers for that.
    Can't I change that? in my motherboards drivers are the VIA and Realtek audio drivers, the VIA drivers make my microphone sound like crap while the Realtek does not.
    Here are the drivers: Here
    Attachment 38506
    Don't know where to find tha info, can you tell me please?
    The ASUS downloads for the motherboard you have listed is VIA. I don't know how you got RealTek to install if you have VIA.
    Version 6.0.1.10100 Copy Link
    Description VIA Audio Driver V6.0.1.10100 for Windows XP 32bit & Vista 32bit & Win7 32bit---(WHQL).
    VIA Audio Driver V6.0.1.10100 for Windows XP 64bit & Vista 64bit & Win7 64bit---(WHQL).
    File Size
    123,98 (MBytes) 2011.12.27 update
    Download from
    Global (DLM) Global P2P
Page 1 of 2 12 LastLast
I am fairly sure I had this manager when I started with windows 8 . I have also done a clean reinstall after hard drive crash. it shows the in and out sockets on the back of the board(gegabyte GA-970A-DP3) AND ALOWS ME TO RE ASIGN THEM.. Can any one tel me how to get it back. very greatfull for...
I have Z87 G43 Gaming Motherboard, it is strange that the Realtek Audio manager no longer starts automatically on startup. I see there is no startup icon in that folder. I uninstalled and reinstalled the Realtek software, but still it does not start automatically. Not sure what could be the issue....
Whenever I use my computer, if I don't play any audio on my computer for a certain period of time, and I have to restart the computer. It's really annoying because I like to view Facebook and Tumblr for a while before I do something such as playing Team Fortress 2. Is there anything I can do...
Hello Dear Friends, I have Asus All In One ET2701INKI, the problem is the microphone does not work properly, It has dense distortion and echo, microphone works in other devices very well, I read many topics in many forums and I tried so many things but there is no solution, I am using...
I'm using a windows 8 pavilion g7 laptop. Long story short, I wanted to have realtek HD audio on my computer mainly for the cool audio effects that come with it because the audio drivers that came with my computer don't have those effects. Nonetheless, I installed realtek HD audio hoping it would...
So i am going to Reset my PC cause of different issues, and i want to export my Presets i made in Realtek HD Audio Manager, the one you make in the Equalizer and then save. I want to know, where are these save, so i can take them over to a USB drive and after the PC is reseted, i only put them back...
Hey guys, My audio disappeared and stopped working. my audio icon has a red x on it and when i click it it wants to detect problems (it doesn't work). what should i do? how should I diagnose the audio? I feel like this is hardware problem as it just happened out of the blue. The audio...
