Audio over hdmi until i plug in earphones an unplug them.
    Texas
    Windows 8.1 & Ubuntu 13.04
    I have a computer i built first one in a long time and its been about 5 years since i have windows. I have the issue that if i boot up it will play audio over hdmi to my tv i have hooked up fine but when i plug in headphone to front jack they work fine. when i unplug my headphones it wont play over hdmi it says there is no devices attached. but i rebot with hdmi plugged in and its fine .
    What Video do you have? You show "Intel" but there are no Intel video cards. There is Intel video built into some CPU's, which I assume is what you have.
    What sound driver do you have for the PC? It looks like the built in audio on that motherboard is VIA. If you do not have the correct VIA driver (e.g. only the generic basic function Windows installed HD Audio Codec), get the driver from MSI. As MSI does not list Windows 8 drivers, the Win 7 will work for Windows 8, but may not work correctly for Windows 8.1. This may or may not correct the problem, but its important to have the correct sound driver, with the jack detection.
    The HDMI, if an HDMI cable is attached normally automatically switches to the HDMI audio output and sets itself as the default audio playback device. Plugging in a headphone, if it changes the audio playback to the headphones instead of HDMI, should automatically change back to HDMI. But, if it does not, manually setting the HDMI as the Default Playback device, in the Sound Panel, should take care of it, rather than having to reboot.
    Texas
    I used the drivers that came on the dvd with the motherboard and updated them . When I first installed windows i had a hard time getting it to go theough hdmi and had to reinstall drivers. I know on the linux side it works fine . Yes i have the Intel 4600 graphics .What is VIA?
    VIA is the audio chip on the motherboard. You need the VIA HD Audio drivers for the PC sound. However, there have been some isolated audio issues and audio driver issues in Windows 8.1. Some audio devices require Windows 8.1 specific drivers to function or function correctly. I've seen a couple of problems posted on here about that. I have a (home) recording studio and ran into that problem with recording interface unit (a Roland Octa-Capture). Roland had to issue Windows 8.1 drivers for it to function.
    It sounds like a driver issue to me. I suggest you download the latest Intel graphics drivers direct from Intel's website.
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel 9.17.10.3040 Playback Devices
Hey guys, I'm new here; I'm having a problem that is bothering me, I recently installed windows 8.1 on my alienware 17x R2, the problem is the laptop never shutdown and still running !, also when I unplug the power cable then plug it back again the windows freeze ! , Note that the battery on my...
My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't...
Hi, before I state my problem I just want to clarify that this didn't occur before updating to windows 8.1. Before the update my sound would switch between the tv and the laptop speakers automatically when as I unplug and plug in my hdmi cable. Now, I put my laptop to sleep when not in use or when...
I just bought a new laptop and tried the HDMI, but there is no audio and the image is poor. It's an Asus X501A with Pentium 2020M Ivy Bridge and Intel HD Graphics. I tried changing the output resolution, to tweak the audio properties, etc. No success. Any idea?
