Dreamdweller
I'm not sure about this problem as I've never had it happen. I have a laptop Windows 8 with a built in mic. Recently I got a very good headset and mic. The connections are both sound jack and mic jack. The problem is that when I go to try and deactivate the built in mic and only use the line-in jack they appear under the same property. If I disable the built-in mic then it seems to disable the line-in jack too. Is there a way to only use the line in jack and disable the built-in mic? As I said when I plug in the line-in jack it appears with the built-in mic.
The other problem I forgot to mention is that when I go the Mic properties it shows the built-in mic. But it doesn't seem to see the one for the line-in jack. I've clicked on the the "show hidden" or "show disabled" field and it still doesn't see it.
- Windows 8
- Computer type
- Laptop
- System Manufacturer/Model
- Satellite C855-S5350
