Onboard Sound: ALC 888s
external DAC/amp: Fiio E17
Connection: ALC 888s out----Optical digital cable-----Fiio e17 SPDIF in
I do not get sound when I set Realtek Digital Output (Optical) as my playback device. I tested the cable and fiio e17 on my PS3 and it works fine. I tried on windows 8.1 and windows 7 and it has the same result. I notice that when i connect or disconnect the cable, Realtek does not say anything.
I have the latest sound drivers and i made sure the sound format was stereo and not surround.
EDIT: fixed. I opened up my computer and i switched to another spdif header. Maybe it was defective or it was loose.
- Windows 7 x64 Home and 8.1 x64 Enterprise
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Acer
- CPU
- Q8400 2.66 ghz
- Motherboard
- OEM
- Memory
- 8 GB DDR2
- Graphics Card(s)
- HD 6970
- Sound Card
- ALC 888s and Fiio e17
- Monitor(s) Displays
- LG W2361V
- Screen Resolution
- 1920x1080
- Hard Drives
- WD black 1 TB
- PSU
- corsair TX650m
