Reducing Volume Amplification?
    Windows 8.1 x64 Pro
    My audio output is my graphics card via HDMI (ATI HD5770) which is connected with my TV.
    I need some software/filters or something else to reduce volume amplification in movies?
    Example, when actors in movies just talking then volume is ok, but if there a war scene then volume jumping up, this blow my mind.
    I've already tried Loudness Equalization, something like this Normalize Windows Volume With These Simple Tricks without success.
    As you are using the HDMI audio and not the regular PC audio, you would have to have some type of control over the HDMI audio process. I have never seen any HDMI controls like are available for the PC audio.
    Some of what you are hearing is because of surround sound. On my HD TV, with surround sound, if I have surround sound enabled on programs with surround sound the announcer (on a sports program) is hard to hear but I can hear other sounds loud. Same way on a movie with surround sound the background music and sound can be louder than the actor's dialog.
    7601.18247.x86fre.win7sp1
    It's dynamic content (wide dynamic range) and intended to be listened to like that.
    You can use PowerDVD. It has an option to lessen the dynamic range while watching. It basically keeps the volume closer to being constant than without using it.
    Windows 8.1 x64 Pro
    I will try. Thanks!
    Edit:
    It would be nice if the ATI in its Catalyst put such a thing.
    CCC is driver-function software intended to make hardware work well.
    This is more along the lines of manipulating content.
    I know you mean for convenience and all that, but adding dynamic compression (like PowerDVD can do for you) is really not a function of the driver.
Mic volume too low in Sound & Audio
Hey is there any way to increase the mic volume besides the one in the controll panal thing? I maxed everything out but it's still not enough ;(...
Solved bsod after reducing available RAM for startup in BSOD Crashes and Debugging
Greetings, Responding to an error code while attempting an install of arcgis, I reduced the amount of RAM for startup under msconfig, advanced, boot.ini. Now I get the bsod with error code bad_system_config_info. Any recommendations for fix? I can't access Windows in any mode but can get to the...
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Solved Volume OSD in Sound & Audio
Solved it on my own! I just ended the Task Manager task, everything seems fine, nothing has died yet :sarc:. So I've been running Windows 8 for a while now, upgraded from Windows 7. Now that Microsoft has implemented a pretty good looking volume OSD I would like to disable the default one....
Solved Win 8 on volume 2,4? in Installation & Setup
Yep guys I've installed win8 on my HDD, after that everytime I boot to win I got this screen: 11368 After 5sec it will be boot to win 8 on volume 2. I have no idea why I have too much win 8 on diffrent volume. Can someone help me fix it?
More...
